I haven't seen this posted before, so I figured I would share:
TMPG Authoring Works 5 (paid software) can create a Blu Ray from a DVD source. If it finds closed captions, it will put them into PGS containers, which are MKV compatible. It retains chapters and proper video length. From there, I use MakeMKV to make MKV files, although the M2TS files will play just fine once the Blu Ray is authored.
Thoughts?
I use CCExtractorGUI for ripping closed captions which can be outputed to .SRT. Then with the .SRT you can use Subtitle Edit to convert to .SUP (PGS), or any other subtitle format you wish. And tsMuxeRGUI is pretty good at extracting .SUP (PGS) subtitles from Bluray .M2TS videos. All free.
I know CCExtractorGUI works on DVDs, ATSC broadcasts, and DVB broadcasts. I have yet to find CCs on a Bluray so I can't test that. -
I use CCExtractorGUI as well. SRT subtitles tend to be more useful to me, particularly if I'm playing video with a built-in TV or Blu-ray media player, which may require subtitles to be in a separate file.
Extract closed captions from PVR
By video2me in forum DVB / IPTVReplies: 56Last Post: 13th Aug 2015, 15:38 -
Closed Captions to SRT and Remuxing
By doctorm in forum SubtitleReplies: 2Last Post: 2nd Apr 2015, 13:09 -
Closed Captions
By cornemuse in forum SubtitleReplies: 2Last Post: 21st Sep 2014, 13:08 -
Can I get closed captions while streaming TV on my PC?
By amazin6 in forum Newbie / General discussionsReplies: 3Last Post: 20th Feb 2014, 16:14 -
Remove Closed Captions?
By Mz Patti in forum SubtitleReplies: 6Last Post: 7th Sep 2013, 02:10
