I'm trying to render a two hour project in Premiere Pro CC 2015, but every time I do, the end result is a video that shows a two-hour runtime but always cuts off around 56 minutes. The file is also half the size it should be, so Premiere is outright failing to render out the entire project. Unfortunately, I've gotten no error messages, and thus nothing to reference when searching for a solution.
File Info:
General
Complete name : E:\Channel\Videos (2016)\TEST.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42
File size : 16.1 GiB
Duration : 1h 50mn
Overall bit rate : 21.0 Mbps
Encoded date : UTC 2016-05-23 23:31:38
Tagged date : UTC 2016-05-23 23:31:38
Video
Format : AVC
Format profile : Main@L4.2
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Codec ID : avc1
Duration : 1h 50mn
Bit rate : 39.8 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Frame rate : 60.000 fps
Minimum frame rate : 60.000 fps
Maximum frame rate : 60.060 fps
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.320
Stream size : 30.6 GiB
Language : English
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 1h 50mn
Source duration : 1h 50mn
Bit rate mode : Variable
Bit rate : 317 Kbps
Maximum bit rate : 383 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Compression mode : Lossy
Stream size : 250 MiB (2%)
Source stream size : 250 MiB (2%)
Language : English
Any ideas?
What do you mean by "cuts off" ? Is it "black", does it continue to play? Or does it stop in the player at 56 minutes?
Have you tried other players? (could it be a playback issue? ) e.g. VLC, MPCHC, Potplayer, SMPlayer
What about audio ? Is it cut off , or blank etc... ?
Before you export, check the preview in AME, and scrub past the 56 minute point, does it look as it should be or is video "cut off" before even exporting?
What about exporting different formats? Try uncompressed AVI for example
A workaround might be to export it in sections as a lossless video and join them if you can get the 2nd part to export -
The player stops at 56:34. I use both VLC and MPC, and it happens in both of them. There is no audio after this point because there is nothing to play. Like I mentioned in my initial post, the file size is about half of what Premiere estimates it should be, so the data just isn't there.
As far as AME goes, I'm not sure what you mean. If you're talking about the preview window, it plays fine there. -
I added some comments after your post.
Test exporting a small section, say from 61 minutes to 62 minutes. Try other formats other than h264/aac/mp4. If you're able to export something past that point, you might be able to salvage the project with a workaround
Is that mediainfo report for the exported file ? Because it doesn't look correct for an Adobe export - it's VFR (variable frame rate), and doesn't have any of the Adobe metadata -
The solution was to delete the video clip that was causing the finished video to stall out halfway through and then reimport it. I guess it got corrupted the first time it was imported.
4k Rendering Issues
By flynnstone in forum EditingReplies: 2Last Post: 4th Aug 2015, 10:23 -
sony vegas rendering issues
By yogurtpooh in forum EditingReplies: 18Last Post: 8th Feb 2013, 11:32 -
Premiere rendering jerkyness or acceleration rendering with MJPEG sources.
By Sennyotai in forum Video ConversionReplies: 4Last Post: 12th Jan 2013, 13:29 -
What is Rendering?
By jbitakis in forum Video Streaming DownloadingReplies: 4Last Post: 1st Jan 2012, 23:27 -
Issues with low memory while rendering Vegas 11
By magic612 in forum EditingReplies: 28Last Post: 8th Dec 2011, 19:49
