So after learning the really basics and understanding how complex it can become i am here
i want you guys to give me some tips on how to properly upscale some anime
with emphasis on darkening lines and making it more colorful (some of the have kinda faded colors)
i included few examples at the bottom
i did a lot of trial and error and came up with variations of this filter
v = LWLibavVideoSource("d:\4.mp4", fpsnum=30000, fpsden=1001, format="YUV420P8")
a = LWLibavAudioSource("d:\4.mp4")
AudioDub(a,v)
ConvertToYV12()
ColorMatrix(mode="Rec.601->Rec.709")
nnedi3_rpow2(2, cshift="Spline36Resize", fwidth=1280, fheight=720)
ColorYUV(cont_u=15, cont_v=20)
FastLineDarkenMod()
Toon(strength=0.6)
dehalo_alpha(rx=2, ry=2.4)
aWarpSharp(depth=6.0)
sharpen(0.30)
how do i know i am not adding to much line darkening ? or over sharpening ? or both?
is there a specific filter for very thin lines?
i also noticed that with some of "dehalo_alpha" settings i can get a niced looking "butter" effect that blurs every thing a little bit and it makes the colors look nicer
any way any advice? what script you would use ? teach me , i am new at this
Why are you scaling twice to the same size with nnedi3_rpow2()? And why are you increasing the saturate of U and V by different amounts? Matching some other video? I generally try to do all the filtering before scaling. And what are the three videos supposed to be showing? 1.mp4 has pretty heavy oversharpening halos. 2 and 3 look acceptable. 1 and 3 have A/V sync problems. But it's hard to judge by looking at only the filtered clips. You should upload original source clips too.
hmm thats the thing this is the source lol
i know they have sync problems its just the vlc recorder thing dont mind that .
some of the original version of 2/3 are 480p and almost look the same
they are "before" i didnt do the after because i am looking for advice before i start
and i am upscaling twice with nnedi3 because it looks like it give a better result ... (see i know nothing) -
I already told you how I would do it. I would do bulk of the filtering before upscaling. So remove the first call to nnedi3_rpow2. You will probably have to adjust the parameters of the filters between the call needi3_rpow2 calls.
Clips 2 and 3 are already 1280x720 so there's no reason to upscale them.
Anime Upscale Script Improvement
By Osram123 in forum Video ConversionReplies: 1Last Post: 9th Apr 2016, 18:21 -
BD-Rebuilder: To upscale or not to upscale, that is the question.
By hbenthow in forum Authoring (Blu-ray)Replies: 7Last Post: 15th Dec 2015, 13:19 -
4k upscale
By Eagleshadow in forum Newbie / General discussionsReplies: 2Last Post: 1st Sep 2015, 09:18 -
Using Nuke to Upscale
By SameSelf in forum Video ConversionReplies: 11Last Post: 31st Aug 2015, 14:52 -
TMPGEnc-menus background going to green screen or previous menu background
By DwightFry78 in forum Authoring (DVD)Replies: 0Last Post: 31st Jul 2013, 14:11
