whats best program to check videos like whats the video format and audio
Results 1 to 9 of 9
I have just done a test on a short mini cam clip its just a test but it says the video is jpeg yet the file says .avi
also how can you change the resolution
Code:General Complete name : M:\DCIM\IOOMEDIA\SUN000.avi Format : AVI Format/Info : Audio Video Interleave File size : 11.3 MiB Duration : 24s 267ms Overall bit rate : 3 889 Kbps Video ID : 0 Format : JPEG Codec ID : MJPG Duration : 24s 267ms Bit rate : 4 714 Kbps Width : 720 pixels Height : 480 pixels Display aspect ratio : 3:2 Frame rate : 30.000 fps Color space : YUV Compression mode : Lossy Bits/(Pixel*Frame) : 0.455 Stream size : 13.6 MiB Audio ID : 1 Format : PCM Format settings, Endianness : Little Format settings, Sign : Signed Codec ID : 1 Duration : 24s 145ms Bit rate mode : Constant Bit rate : 256 Kbps Channel(s) : 1 channel Sampling rate : 16.0 KHz Bit depth : 16 bits Stream size : 755 KiB (7%) Alignment : Aligned on interleaves Interleave, duration : 128 ms (3.85 video frames)
AVI is just a type of container used to hold video and audio. Most people associate DivX or XVid with AVI, but AVI is compatible with many other types of video and audio, including MJPEG video and PCM audio, as shown for your file.
To change the resolution you would need to re-encode the video to the desired resolution. Cropping or padding may be necessary if the current aspect ratio is correct, but you want the resulting video to have a different aspect ratio. -
ok but if i play this short clip in videolan the quality is terrible but if I play it in windows media player its much better so why when using videolan the quality is rubbish
Don't know for certain since we don't really know your file nor your installed system. But in general, the difference comes down to playback architecture & codec settings. Vlc uses its own set of portable decoders & demuxers, wmp uses existing installed OS/system Directshow decoders & demuxers. Often vlc has better performance than wmp but of course YMMV.
Just Checking RE Windows 7 Install Disk
By Frank-0-Video in forum ComputerReplies: 3Last Post: 16th Apr 2016, 15:03 -
Ripbot 1.18.1 No AUDIO when checking file to convert
By Myrr in forum Video ConversionReplies: 5Last Post: 13th Mar 2015, 19:28 -
Checking VOBs for validity (truncation).
By JN in forum Video ConversionReplies: 2Last Post: 26th Aug 2013, 05:52 -
Checking Blu Ray
By nickflix in forum Blu-ray RippingReplies: 2Last Post: 4th May 2013, 18:18 -
checking avi attributes.
By David Banner in forum EditingReplies: 8Last Post: 30th Sep 2012, 23:00
