I just can't believe how counterintuitive these video editing programs are, when it comes to something as simple as deleting a section of the video.
I'm trying to cut some advertisements out of an MPEG video using Mpg2Cut2. I can easily see how to mark the beginning and end of the section I want to delete, but, I cannot see a 'delete' submenu option under any of the menu options, particularly, the 'Edit' menu option.
Would someone please either explain to me how to do this, or point me in the direction of a guide?
-Mike
You could select the parts you want to keep with [ and ].
Click on the + button.
Last File->Save All Clips and you will get one mpg.
As I don't think you can delete clips.
Or use avidemux, open mpg, under video and audio choose copy, set start and stop for clips you want to remove, press delete on your keyboard and last save as format: mpg(mpeg-ps). -
MPEG-VCR is a lower-cost ($19) alternative to VideoReDo if someone only needs to cut MPEG-2. Use the free trial to see if you like it before buying.
However, I would suggest trying VideoReDo or TS-Doctor instead to someone who is cutting recorded TV files originating from a TV tuner card as those often contain transmission errors that other editors cannot handle.Last edited by usually_quiet; 23rd May 2016 at 14:08.
Just for the record, two other very nice MPEG-2 edit programs are: Womble MPEG Video Wizard DvD (the "big brother" of the mentioned MPEG-VCR) and TMPGEnc MPEG Smart Renderer.
Like the mentioned VideoReDo, they are very easy to use, and only re-encode just a few frames at the cuts (and joins) saving tons of time and quality in processing.
Also, like VideoReDo, they are not free. If it's an isolated project you're working on right now, I say go ahead with Baldrick's advice, but if you are planning to do lots of work with MPEG-2, these I highly recommend for looking into as a worthwhile investment in productivity.I hate VHS. I always did.
mpg2cut2 wants to "inject code".
By bluesbabe2 in forum Newbie / General discussionsReplies: 2Last Post: 25th Jul 2015, 07:49 -
MPG2Cut2 to FFMPEG MP4 vs FFMPEG MPG2 to MP4 AviDemux
By RedPenguin in forum Video ConversionReplies: 4Last Post: 29th Apr 2015, 13:16 -
mpg2cut2 - joined mpg2 files not seekable in WMP
By Special K in forum EditingReplies: 6Last Post: 15th Mar 2014, 21:50 -
Program Similar to Mpg2Cut2 - But for Blu-Ray / HD-DVD Content
By devilcoelhodog in forum Authoring (Blu-ray)Replies: 16Last Post: 27th Aug 2013, 13:20 -
Looking for a TV recording Guide!
By tential in forum DVB / IPTVReplies: 7Last Post: 21st Jul 2013, 13:18
