Two things
-how do i get the exact frame showing on the video player i'm using (mpc-be)
-whats the quickest and most accurate way after i have the frames to do a one click, no rencode trim
Like a script "save (1123-4567)" where first and second number are start-end frames.
Both x264 and x265 are 'long GOP' (long Group of Picture) formats, so you will only be able to cut - without recoding - on 'I' frames (Keyframes).
Each GOP can be a different length from those before and after, depending on content, so it is difficult to know exactly where you will be able to cut.
x.264 files will have an I frame every approx 25-50 frames. x.265 'GOPs' can be up to 200 frames long - or even longer.
If you want to cut with frame accuracy, you can either re-encode the whole file to an intraframe (all keyframe) format, or use a video editor which allows 'smart rendering', so that only the area around your chosen cut point is re-encoded. (The editor will build a new GOP around the cut)
Whether you feel the need to go that far will depend how accurate your cuts need to be ?...... -
I just need to clip excerpts of videos just for fun nothing professional
But frame accurate just means it will not go way of scene
I tried solveigmm video editor. It did not open h265, and on h264 it asked for ac3 filter to be installed. Doesnt it habe internal filters
H.264 vs x264 and H.265 vs x265
By LeoKac in forum Video ConversionReplies: 27Last Post: 18th Jan 2017, 08:59 -
4K HEVC H.265 encode board
By hi3516a in forum Newbie / General discussionsReplies: 0Last Post: 5th May 2016, 10:41 -
x264 vs 265 question (4/3/2016)
By nixiejames in forum Video ConversionReplies: 6Last Post: 4th Apr 2016, 15:54 -
Encode h.265
By sportsstar89 in forum Video ConversionReplies: 13Last Post: 5th Jan 2015, 04:00 -
Simple x264 265 -- How many steps to get video and audio
By loninappleton in forum Newbie / General discussionsReplies: 0Last Post: 22nd Nov 2014, 04:50
