I sometimes edit the audio of an mp4/avi by opening the video with WavePad, making my changes to the audio, then saving a new mp3 file. Avidemux is then used to put the new audio on to the video but, very often, there's a burst of static at the start. I've no idea why that should be, it seems to depend on where you cut the video originally.
It was suggested to me that I save a wav file rather than an mp3 and let avidemux do the conversion to mp3. This plan works insofar as the 'static' problem doesn't arise but I now have another problem as shown in the attachments. Can anyone suggest why the volume is being lowered and how to prevent this? Thank you for your time.
mp4/avi? Do you mean divx/xvid or H264 ? NO need to be coy, the more details the better.
Why don't you use Virtualdub to add the new audio to the avi ? -
Make sure you don't have the audio filters set set change the volume. For example, make sure Gain Mode is set to None.
Avidemux crashes when I open videos with subtitles muxed in them
By TheRandomOne in forum Video ConversionReplies: 4Last Post: 5th Jan 2016, 16:03 -
Avidemux won't release edited FLV files
By JLJomatic in forum EditingReplies: 3Last Post: 25th Apr 2015, 18:41 -
Save edited AVIs in Avidemux without reencoding.
By ts1971 in forum Newbie / General discussionsReplies: 2Last Post: 25th Nov 2014, 17:35 -
Avidemux loses all audio when I use audio shift option
By itm2 in forum EditingReplies: 5Last Post: 31st Mar 2013, 16:39 -
Mpeg edited with Avidemux won't play in Pinnacle Studio 7? Please help!
By pf4711 in forum Newbie / General discussionsReplies: 4Last Post: 23rd May 2012, 13:37
