I have a cousin who compiled a video using his i-phone (mov file). The file is a little over 3GB in size and when played using Windows Media Player, looks real good (sharp and little pixilation). (The resolution of the original is 3840x2160.) I've tried a couple of mov to mpeg converters, but when played (Using Windows Media Player), the mpeg files look coarse, and just don't look too good, especially with motion. The ultimate goal is to make a DVD from the video (preferably with a menu) which preserves as much of the original video (and) quality as possible.
Any suggestions on tools or techniques for the conversion? Thanks
	Ditto. Just understand that NTSC DVD video is 720x480 so you'll be taking a big step down in resolution
	Normally yes but in this case I don't think so. I don't have iPhone 4k videoes but I would guess they use a bit rate about 50 Mb/s (The OP could use MediaInfo - View -> Text to provide the info) and with the size of the source file being "a little over 3 GB" and the max (total) bitrate for a DVD is 10.08 Mb/s (and AVStoDVD using 8.5 Mb/s for the video)) he can't even fill a DVD5.You'll get better quality making a DVD-9
 Also as settings he'll need to choose HCenc 2-pass under Preferences in order for that to be used with such a short playtime.
	I went with the HC 2 pass setting and as mentioned, the video only partially filled a DVD 5 (plenty of room there). The results were great in terms of video quality compared with previous mov conversions with one exception. The first 45 seconds or so played fine, but on one transition (a fade made in the iPhone app) the video (now being played from a burned DVD) went to a totally blue screen (very briefly) and after that point all blacks took on a blue hue. It looked level sensitive since during the fade to a scene the blacks would be ok but as soon as the transition finished and the scene was fully faded in, blacks would fill with blue. This doesn't show up on the iPhone itself or previous tries with mov to mpg conversions when the mpegs were viewed with Windows Media Player. I'm wondering if there's a filter setting that is responsible? Not a clue here??? But the video quality other than that problem is excellent.
	My bad. The blue that showed up in the shadows was due to a "Vintage Filter" my cousin used when he originally transferred the video from his I phone (thought it improved the video). He removed it - made another transfer, and all is well. Good video quality and the transcoding went great. Thank's for all the help folks.
 By the way, he discovered the problem on his own but I'll never let him forget this one. We both learned a lot.
  .amr (audio) file from phone.By racer-x in forum AudioReplies: 2Last Post: 16th Nov 2014, 19:54
  Upside down .MOV clip from a phoneBy fiiido in forum EditingReplies: 1Last Post: 1st Feb 2013, 05:23
  Need to make a mov file smaller without losing its video qualityBy shesterz in forum MacReplies: 4Last Post: 28th Jun 2012, 08:30
  Phone froze while recording, HELP ME SAVE MY FILEBy boostjunkie92 in forum Newbie / General discussionsReplies: 7Last Post: 11th Oct 2011, 14:41
  .MOV conversion to .AVI and .MOV HD quality queryBy Peewitisland in forum Newbie / General discussionsReplies: 3Last Post: 31st May 2011, 12:22
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
