Results 1 to 12 of 12
  1. Hello there.
    I'm very advanced when it comes to edit and author dvds (I'm familiar with many programs: Dvd-lab PRO 2, MPEG Video Wizard, AVStoDvd, Sony Vegas, etc etc), but I'm a complete newbie when it comes to blu ray.
    I've bought a LG bd recorder and I would like to start my first project. I have the a .ts file (17 gb) of a concert and I would want to make a blu ray out of it. Where do I start from? Any suggestions would be much appreciated. I tried to browse through the guides here on Videohelp, but I'm a bit confused and still not sure what's the best thing to do.
    Thank you so much in advance for taking the time to help!
    Nov 2003
    West Texas
    What do you want to do with the .ts file? Do you need to edit it in any way? Or apply filters? Is the .ts file as it exists now already compliant to Blu-ray specifications? Do you want a menu?
    If none of these are problems, then it is very simple to get the .ts file into Blu-ray format without a menu. Just use tsMuxeR.
    Best to use MediaInfo and post the results here in your thread. You'll give the members here a better idea of what you have to start with. I find the text or tree views in MediaInfo to be the most informative.
  3. I think it's already compliant (I'm pasting the specs at the bottom of this post).
    I don't need to edit it in any way. I would only want to add chapters and try to make a menu.
    Format : MPEG-TS
    File size : 17.1 GiB
    Duration : 2h 39mn
    Overall bit rate : 15.4 Mbps
    Video
    Menu ID : 1 (0x1)
    Format : AVC
    Format profile : Main@L4
    Format settings, CABAC : Yes
    Format settings, ReFrames : 4 frames
    Format settings, GOP : M=3, N=15
    Codec ID : 27
    Duration : 2h 39mn
    Bit rate mode : Variable
    Bit rate : 14.2 Mbps
    Maximum bit rate : 14.5 Mbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate : 25.000 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Interlaced
    Scan type, store method : Separated fields
    Scan order : Top Field First
    Bits/(Pixel*Frame) : 0.274
    Stream size : 15.8 GiB (93%)
    Color range : Limited
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    Audio
    Menu ID : 1 (0x1)
    Format : MPEG Audio
    Format version : Version 1
    Format profile : Layer 2
    Mode : Dual mono
    Codec ID : 3
    Duration : 2h 39mn
    Bit rate mode : Constant
    Bit rate : 384 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Compression mode : Lossy
    Delay relative to video : 11ms
    Stream size : 437 MiB (2%)
    Language : English
    Language, more info : Clean effects
    Nov 2003
    West Texas
    Making menus for Blu-ray is one of the biggest issues for free programs. You might try multiAVCHD, but you'll need patience. It is cranky, slow and buggy in my experience.
    MP2 audio might be another problem. I'd probably convert to AC3.
  5. DECEASED
    Jun 2009
    Heaven
    Since the audio stream has only 2 channels, I would choose uncompressed PCM.
    Acceptable filesize, and no loss of quality.
    May 2014
    Memphis TN, US
    At the risk of offending and contradicting everyone here at videohelp, I'd offer that published specs say a GOP of 15 is not strictly BluRay compatible. Many authoring programs will re-encode the video for BluRay. It might work for AVCHD but I never tried it. Then again, MediaInfo doesn't always report GOP size or other factors accurately.
    http://forum.doom9.org/showthread.php?t=154533
    - My sister Ann's brother
    Jul 2010
    Canada
    I don't understand...the link you posted says that AVC 1080i with a 25.000 framerate can have a maximum of 25 frames per GOP. Thus with GOPs of 15 frames, it should be compliant.
    May 2014
    Memphis TN, US
    So, go ahead and try it.
    Jul 2010
    Canada
    I have TMPGEnc Authoring Works 5, and it works. Then again, I didn't understand your explanation. You say it won't work, but posted a link to a site that says it's compliant. What I am missing here ?
    Aug 2006
    I don't know if a GOP of 15 is valid, but the GOP length is most definitely allowed to be less than the frame rate. I examined at a commercial Blu-Ray disc from Warner Brothers with DVDFab Passkey running in the background. The video is 1080p23.976 AVC High@L4.1. The GOP length is 20. (I counted the number of frames per GOP manually in an editor.)
    The specs at LMotlow's link said 24 frames per GOP for 1080p23.976 AVC High@L4.1. I'm guessing that is the maximum number of frames allowed per GOP for video with those specs, not the minimum. The chart says it is the maximum.
    Nov 2003
    West Texas
    After a bit of reading, it seems that bitrate affects GOP length in Blu-ray video. With less than 15mbps bitrate, a two second GOP is allowed, anything more requires max 1 second GOP, which with this example would be 25. But shorter GOP's are allowed, especially with open GOP's. (don't know which he has)
    Try it in TMPGEnc Authoring Works. You'll learn more by experimenting than waiting for us to confuse you.
    If burning to discs, this would be a good time for a BD-RE, to test in a few players.
    May 2014
    Memphis TN, US
    That's what I said. Try it . If TAW5 took it, anything will.
