Hi,
I am trying to create a simple menu in MultiAVCHD with no motion, sliding tiles etc. Just text (that I want to place at the top of the screen) that I can click on, 'Play' and 'Bonus feature', and a looping MP3 playing in the background. I have my own JPEG for the background image.
I have 2 movies going onto this project that I want to be able to select from one main menu.
When I preview the top menu, it seems that there is a menu for both movies.
Am I missing something? I am VERY new to this, so go easy on me.
Is there better software that I can use?
Thanks in advance,
Si
Do you get two similar menus when your preview?
I would try output and test play with PowerDVD or some software player that supports blu-ray menus.
I don't think you will find that many other free blu-ray authoring apps....or try commercial software like tmpgenc authoring works.
multiAVCHD kills my BD Menus
By vfxhooker in forum Authoring (Blu-ray)Replies: 5Last Post: 17th Jan 2016, 01:31 -
.TS files jumping after authoring with MultiAVCHD/TSMUXER
By digitalfreaknyc in forum Authoring (Blu-ray)Replies: 8Last Post: 24th Jun 2015, 19:57 -
Problem authoring .m4v file using TSMuxer/MultiavcHD
By digitalfreaknyc in forum Authoring (Blu-ray)Replies: 4Last Post: 29th Sep 2013, 09:02 -
Custom menus in multiAVCHD...
By calgunner in forum Authoring (Blu-ray)Replies: 1Last Post: 10th May 2012, 19:35 -
Menus & Chapters Multiavchd
By funkyirishman in forum Authoring (Blu-ray)Replies: 4Last Post: 30th Dec 2011, 12:08
