Is there an easy, automatic way to separate videos with sound from videos without sound? I know mediainfo can produce custom info on a bunch of video files but then I would have to individually separate them while reading the CSV. I have hundreds of videos that I need to post-process in the same folder and I need the ones without sound in a separate folder.
If you're using Windows Explorer, switch to Details view, add "Bit rate" to the displayed columns, then sort on it. Files without a bitrate have no audio.
separating a vocal from audio track
By efiste2 in forum AudioReplies: 11Last Post: 21st Nov 2014, 11:43 -
separating an audio track to remove certain sounds
By efiste2 in forum AudioReplies: 4Last Post: 6th Aug 2013, 04:24 -
Separating out a voice in the crowd
By and in forum EditingReplies: 1Last Post: 8th Dec 2011, 09:20 -
Separating a fade from video in Vegas Pro 10?
By gutterboy in forum EditingReplies: 3Last Post: 10th Oct 2011, 18:23 -
best program for separating one large MPG file to several sequential files
By nplovernmi in forum EditingReplies: 3Last Post: 20th Aug 2011, 18:09
