I have an avi and an identically named srt file in the same folder, but when I open AviAddXSubs, select the avi, and click Start, all I get is, "Failed, video stream not found." What's wrong with the damn thing?
				Results 1 to 24 of 24
	Here's all the MediaInfo.
 General
 Complete name : C:\Users\Bruce\Desktop\test.avi
 Format : AVI
 File size : 385 MiB
 Duration : 52mn 32s
 Overall bit rate : 1 024 Kbps
 Writing application : Lavf57.36.100
 Video
 Format : AVC
 Format profile : High@L4.1
 Format settings, CABAC : Yes
 Format settings, ReFrames : 8 frames
 Codec ID : avc1
 Duration : 52mn 32s
 Bit rate : 915 Kbps
 Width : 1 280 pixels
 Height : 720 pixels
 Display aspect ratio : 16:9
 Frame rate : 95.904 fps
 Original frame rate : 23.976 (24000/1001) fps
 Color space : YUV
 Chroma subsampling : 4:2:0
 Bit depth : 8 bits
 Scan type : Progressive
 Bits/(Pixel*Frame) : 0.010
 Stream size : 344 MiB (89%)
 Writing library : x264 core 148 r2597 e86f3a1
 Encoding settings : cabac=1 / ref=8 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=12 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=2pass / mbtree=1 / bitrate=915 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=40000 / vbv_bufsize=40000 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00
 Audio
 Format : AAC
 Format profile : LC
 Codec ID : FF
 Duration : 52mn 32s
 Bit rate : 81.1 Kbps
 Channel(s) : 2 channels
 Sampling rate : 48.0 KHz
 Frame rate : 46.875 fps (1024 spf)
 Compression mode : Lossy
 Stream size : 30.5 MiB (8%)
 Alignment : Aligned on interleaves
 Interleave, duration : 21 ms (2.05 video frames)
	AFAIK it suports only xvid and divx. Your video is H264.
 AVIAddXSubs is a simple free program to incorporate subtitles from .srt (ANSI text, up to 2 srt) or idx/sub (containing up to 8 subtitles) quickly and easily to your avi files containing DivX/XVid video streams.
 You can try to remux your video in MkvtoolnixGUI and insert subtitles to container. So you will have one file with subtitles inside.
 BernixLast edited by Bernix; 18th May 2016 at 21:37.
	Great, thanks for the advice. I'll try reencoding the video with DivX and see whether I can get AviAddXSubs to work then.
	Well I reencoded with Xvid and AviAddXSubs worked fine. It created a .divx copy of the video. But I couldn't get the subtitles to work. What did I do wrong?
	I dont know nothing about PS3 but there is some video that tells it can play mkv. Mkv is only container it can contains any video or audio.
 https://www.youtube.com/watch?v=WqCjhdbiot0
 But I really cant helps with AviAddXSubs
 Bernix
	mkvs only work on ps3s if you're using ps3 media server. That's too complicated for me and I'm not interested in streaming anyway. I just wanna be able to plug a usb drive into the ps3 and play videos that way. In order to be able to do that with videos with external subtitles, I need to know how to use AviAddXSubs properly.
	O.K. have you read this ? http://www.guidingtech.com/18623/add-subtitles-ps3-videos-read-srt-files/
 and I have to say that aac audio isnt standart for avi. Try to convert it to mp3 then.
	Thanks. I have read that and unfortunately, for reasons I cannot figure out, the ps3 won't detect the video. That instruction guide said once you've created the video, put it on a usb drive and plug it into the ps3. I did that and the ps3 detected the usb drive but couldn't find the video on it. I was definitely in the video column of the ps3 menu but it said no titles found.
	It's .divx That's the extension of the file AviAddXSubs creates. Should I just try changing it to .avi? That guide you posted said nothing about that. It just said copy the video to a usb drive.
	have you firmware 2.20 or higher in PS3 ? and more here http://aviaddxsubs.blogspot.cz/
	I don't know. How do I check that?
 https://www.youtube.com/watch?v=DnJ9gzbQ-vs
	To play the video on a ps3 don''t click on the usb icon right away,click on the green triangle on your ps3 remote control and select Display All and then you will see your video,as to encoding with handbrake or vidcoder you need to set the bitrate or otherwise you get big files.
 Choose constant quality 20 and it will you a smaller file size.I think,therefore i am a hamster.
  AviAddXSubs subtitle extraction/edit?By Kracov in forum SubtitleReplies: 2Last Post: 19th Feb 2014, 09:46
  AVIAddXSubs "movie-name.avi" not foundBy ydobpbkwds in forum SubtitleReplies: 4Last Post: 2nd Dec 2011, 16:00
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
