Results 1 to 9 of 9
  1. i have been looking for screenshot generator which generate screenshot from video files from the context menu by right clicking the video file i have have to generate screenshot is their anything like that? i have used one which generate from batch processing the video file but i just forgot its name it works without playing the file just right click and click generate screen shot sit back and enjoy is their anything like that
    You can use MPC-HC, under file->save thumbnails.
    or maybe Auto-Movie-Thumbnailer or Video Thumbnails Maker has the right click feature.
  3. Or you can use ffmpeg.
    ffmpeg  -i "%1" -vf "scale=320:-8:sws_flags=spline,select='gt(scene\,0.02)',tile=4x3" -vsync 0 "%~n1_%%03d.png"
    There is also new filter called 'thumbnail' and it may be better to perform such task.
  4. i cant find right click function on amt
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    Nope. I have no idea. If you ever find the software with the right click screenshot feature let us know.
  6. and way it helps me now i can generate screenshots without playing it
  7. the software with the right click screenshot featur
    Or you could make it yourself.
    I took Pandy's ffmpeg command and made it to a batch file.
    Then I used Types to add it to context menu for MKV (you could use other software for this)
    It produces thumbnails as attached.
    You could also use Video Thumbnails Maker CLI ( License version only) instead of a ffmpeg command.
    PS: Correction: Video Thumbnails Maker CLI is now free. Appearently been so since vers. 6.0.0.0
  8. I'm a MEGA Super Moderator Baldrick's Avatar
    Great solution! You can even customize the thumbnail genaration then.
  9. Originally Posted by videobruger View Post
    Would you please post your batch script?
