Hello, I have several small personal videos that I would like to split at certain points. I have watched the videos and noted the exact time where I would like to make each split. I would like to find a way either using Window's Movie Maker or possibly another editing software that someone suggests to jump to a specific time in the clip for example jump to 50:17 in the clip so that I can then do a split of the clip at that point. I have not been able to figure out how to jump to a specific time like that aside from trying to eyeball it using the slider in the timeline. Any help with this would be greatly appreciated.
Results 1 to 9 of 9
Hi,
what format is your video ? x264, xvid, mpeg etc. ? If is it avi, you can use Virtualdub. Goto and set time. But you will have to reencoded most probably.
Bernix -
Hi Bernix, Thank you for replying to my post. The videos that I am working with are 1024 x 576. They are MP4 videos. I have attached the first one in case you need to see that. Thanks
Ron -
Hello Again,
Thank you Bermix for telling me about Avidermux. I downloaded and installed it. I am able to use Ctrl-T to jump to a specific point. Do you know where I can find a manual or a basic tutorial video for this program? I am a total newbie when it comes to video editing and I am having a hard time figuring out the basics using this program. Thank you again for your help.
Ron -
I think there will be some videos on youtube.
And I found this http://filmora.wondershare.com/video-editor/free-video-editor-avidemux.html
There is plenty of videos on youtube. But I found them not very good.
And use much lower bitrate about 200kb, because in your example there are still pictures. So no 1000 as is in tutorial above
BernixLast edited by Bernix; 18th May 2016 at 14:52.
Hello again,
I think I am all set now. The html tutorial plus a couple of youtube videos helped me get a few basic instructions so I can do what I am trying to do. Thank you so much for all of your help with this Bernix
Any way to delay audio at a specific time
By hugopiugo in forum AudioReplies: 5Last Post: 23rd Oct 2015, 21:36 -
ffmpeg mute specific time
By tb582 in forum EditingReplies: 2Last Post: 9th Apr 2015, 17:26 -
How to download only specific time frame
By aliv in forum Video Streaming DownloadingReplies: 6Last Post: 11th Jul 2014, 01:14 -
mkv jump to time not working properly
By Nmid in forum Newbie / General discussionsReplies: 6Last Post: 27th Feb 2014, 05:24 -
[help] Jump to specific url after playing wmv video file
By techtonik in forum Newbie / General discussionsReplies: 1Last Post: 17th Jul 2011, 07:23
