I'm trying out some different settings for encoding 264, however, I'm unclear as to whether or not I should use Trellis.
What are some recommendations/suggestions?
Trellis for I, IP, Auto, Off, etc.
Other settings are basically defaults and I usually use a Constant quality between 19-21 for 720p and 1080p material.
Thanx in advance.![]()
Read over the trellis(vidcoder) and it will tell you it gives you 3-5% more compression at the cost of some speed,always on means it will be use in encoding and analysis modes,encode only means it used during the encode mode.
According to what I read in the Wikipedia article about Trellis quantization, it is supposed to find the optimum. So if I were interested in quality as good as possible, in the given limits of bitrate, I would use it.
What is the difference between x264 and h264? And why are they so popular?
By KyleMadrid in forum Newbie / General discussionsReplies: 23Last Post: 25th Oct 2018, 10:03 -
h264 vs H264, x264 vs X264
By MarioPL98 in forum Video ConversionReplies: 15Last Post: 18th Aug 2015, 13:26 -
encoding with x264 and h264 codec only use 30-50% cpu
By Slind in forum Video ConversionReplies: 32Last Post: 26th Nov 2013, 20:29 -
Is my thought process correct H264 vs x264?
By LoveDeezNutz in forum Video ConversionReplies: 3Last Post: 6th Jan 2013, 20:12 -
.MP4 H264/x264 to XviD (stand-alone player)
By vieekk in forum Video ConversionReplies: 12Last Post: 9th Aug 2012, 13:48
