I have a DivX movie with 24 fps. How can I convert this to (S)VCD ?
(I have tried the following with no lock (sound out of sync)):
http://www.vcdhelp.com/divxtovcd.htm
24fps is possibly actually 23.97fps (dont trust file-properties under win2k/XP, open the file in virtualdub to check). In that case it is a NTSCFilm format, so select the relevant template in TmpGenc. If you cannot handle NTSC playback on your DVD/TV then you will have to convert it to PAL. This is a long and difficult process but can be done, see the Howto's for details.
Is the FPS of a MiniDV camera higher than the FPS of DVD video?
By granturissimus in forum Newbie / General discussionsReplies: 8Last Post: 9th Jan 2011, 05:40 -
mixing 1280 x 720 29,97 fps and 1440 x 1080 25 fps in final cut
By perik in forum EditingReplies: 6Last Post: 17th Nov 2010, 22:42 -
How to convert a video of 120 Fps to... well 23.9fps or 25 fps or 30 fps
By Chuba753 in forum Newbie / General discussionsReplies: 7Last Post: 6th Jun 2008, 19:17 -
Divx to NTSC DVD: is Dgpulldown needed if Fps is 23.976?
By kalii2 in forum Video ConversionReplies: 4Last Post: 20th Jan 2008, 08:29 -
30 fps flv to 25 fps avi or vcd
By cd090580 in forum Video ConversionReplies: 5Last Post: 12th Nov 2007, 08:35
