After I install cumulative security update 911567 for Outlook Express when i try to open it Address Book I receive an error message that resembles the following:
Unable to open Address book. Address book may not be installed correctly
Anyone else having this issue?
It looks like common problem.
https://support.microsoft.com/en-us/kb/917288 with solution.
Bernix -
To resolve this issue, follow these steps:
1. Uninstall cumulative security update 911567. To remove this update, use the Add or Remove Programs item in Control Panel. System administrators can also use the Spuninst.exe utility to remove this security update.
2. Copy the .wab file that is located in the following folder:
C:\Documents and Settings\<user>\Application Data\Microsoft\Address Book\<user.wab>
Paste a copy of this file in the following folder:
C:\Documents and Settings\<user>\Desktop\backup.wab
Note In this step, <user> is your Microsoft Windows user name. Make sure there is no <user>.wab file on your Desktop.
3. Click Start, click Run, type cmd, and then click OK.
4. At the command prompt, type the following, and then press ENTER:
Del "C:\Documents and Settings\<user>\Application Data\Microsoft\Address Book\<user>.wab"
5. Start Outlook Express.
6. On the Tools menu, click Address Book. Notice that the Address Book does not contain any contacts.
7. On the File menu, point to Import, and then click Address Book.
8. Import the backup.wab file that is located in the following folder:
9. Install the most recent cumulative security update for Outlook Express If you are still experiencing the issue I can suggest this program Address Book Fix Toolbox https://www.fixtoolbox.com/addressbookfix.html
Note If you find more than one .wab file, rename the user name with which you are currently logged in. If the user name is the default user name, the file name is Default.wab.
After you apply these changes, import all contacts that are contained in the old .wab file to the new profile that you have created. All contacts that are contained in the .wab file are imported to the new profile. During importing, folders are not recognized. Therefore, all contacts are imported to the profile. If you have shared groups, these groups are imported to the profile.
Vidcoder is unable to open AVCHD camcorder files.
By Stears555 in forum Video ConversionReplies: 3Last Post: 1st Jun 2015, 17:03 -
Unable to open stream in VLC (log included)
By mortpiedra in forum Newbie / General discussionsReplies: 0Last Post: 5th Apr 2015, 14:15 -
Urgent VLC is unable to open MRL http
By Sam Qur in forum Video Streaming DownloadingReplies: 0Last Post: 2nd Apr 2014, 11:57 -
Unable to open some files. what's Windows file name character set?
By Zephir in forum ComputerReplies: 11Last Post: 10th Jul 2012, 14:52 -
unable to open video file
By edu4rd in forum Newbie / General discussionsReplies: 2Last Post: 27th Dec 2011, 13:22
