  1. Hi,
    Me using the latest version of AviDemux 2.6.12 <portable> .
    When ever i try to convert any files to H264 output,, Avidemux not able to do so,,,it pop up this message "cannot setup codec. bitrate too low" .. what bug is this ?? But it works smoothly when use Output as H265
ID:	37031----->> Name:  2.png
  2. Member Bernix's Avatar
    Apr 2016
    Europe
    You must use MP4 AVC(x264) and not this H264(ff/nvidia)
  3. Originally Posted by Bernix View Post
    yes i have also notice it just now,when i use that avc (x264) option it works perfectly ... why that H264 not works !
    and is there bitrate calculator in avidemux ?
    as i want to know what will be the actual size of the vid when convert it to so & so bitrate... in avc (x264) & h265
  4. Member Bernix's Avatar
    Apr 2016
    Europe
    I think it supports only some sort of nvidia. But MP4 AVC (x264) will have always better result. You can setup much more things. In ff/nvidia you can setup only bitrate.
    Bernix
  5. okies got it bernix.. thanks for it
    but bitrate cal ?
