Results 1 to 11 of 11
  1. Hi! Can anyone help me with this in VD? When I run the avi in VLC everything is ok, but when I want to process it in VD I canīt since it is somehow deformed. I upduted Xvid but it did not help. Thank you!
Size:  88.4 KBClick image for larger version
    Last edited by vratislav; 6th Jun 2016 at 18:10. Reason: more descriptive title requested
  2. Consider changing VD to my pack https://forum.videohelp.com/threads/378401-VirtualDub-fork-and-plugins
    If there is problem, upload video fragment.
    Nov 2002
    video resolution is an un-even number. change to even number.
  4. The decoder you're using for your source can't handle the mod2 frame width, it requires mod4. Use another decoder. For example, use Xvid instead of ffmpeg.
    Aug 2013
    Central Germany
    A slightly more descriptive thread title would have been useful...
  6. thanks! your pack is great
  7. Originally Posted by LigH.de View Post
    is it possible to edit it to make it more descriptive?
  8. Originally Posted by shekh View Post
    THX it works well!
  9. DECEASED
    Jun 2009
    Heaven
    Click the button named "Edit", then click the button "Go Advanced".
  10. Originally Posted by El Heggunte View Post
    Done THX!
    Aug 2013
    Central Germany
    Well done, now that's descriptive. Even including a little language play (odd in both meanings - "strange" and "mathematically uneven").
