I do a lot of screen capture and play them thru my media player in the house, but would like to cut sections out and save with out re encoding them and would prefer freeware if it is available. These can be pretty long videos and I have some software that will do it the long way cutting everything around it out and wants to re encode which I don't want to do. Thanks for any help
I wouldn't suggest doing captures with .WMV, as the tool support is limited. I'd encode using x264/XviD/MJPEG/lossless(Lagarith/Huff/FFV1/...) What program are you screen capturing with?
The best free program I can suggest is AsfBin, which can accept most .ASF or .WMV files and cut them up. It seems to save cut .WMV files as .ASF but I just change the file extension back to .WMV and it seems to work fine. -
Im using Replay Video Capture, it has always worked good for me other than file size can be a bit big since most everything I capture is slow movement. My device I use for all my playing is a med800x3d which play most everything but there
has been a few not play but most have if there standard format
Thanks for the help
I looked at the description for Machete, which says it can cut WMV files on keyframes (I-frames). That would be lossless, but it wouldn't be possible to cut anywhere that the user would like. The program moves cuts to the nearest keyframe if the user doesn't place the cut on a keyframe himself.
The description for SolveigMM Video Splitter says it can edit WMV files. This program smart encodes (only re-encodes partial GOPs adjacent to the cuts) for some types of video, but cuts other types of on keyframes/I-frames. I'm not sure which it does for WMV.
These are not free but have free demo versions to try to find out if they are worth paying for.Last edited by usually_quiet; 17th May 2016 at 01:07.
how to Cut some parts from video
By Aashik Alam in forum EditingReplies: 6Last Post: 12th Nov 2015, 09:35 -
Rip a dvd and cut parts(frame) out of the movie while keeping subtitles
By sgcdec in forum DVD RippingReplies: 4Last Post: 14th Feb 2015, 05:28 -
I would like to cut this file into its constituent parts
By RBCC in forum Newbie / General discussionsReplies: 4Last Post: 22nd Apr 2014, 00:47 -
Cut M2V file into several parts
By nonoitall in forum EditingReplies: 2Last Post: 17th Apr 2013, 06:56 -
Experience of lifetime – cut out parts of DVD to make a smaller version
By technogeek in forum Newbie / General discussionsReplies: 3Last Post: 10th Sep 2011, 01:28
