  1. Hi there , I need to adding intro(which created in After effects, and encoded to mp4 format) to each video from list of 100+ videos(which also mp4 format)
    I try it with the concat command of FFMPEG, but I always have problem with "Non-monotonous DTS errors" , I understand that maybe I should re-encode the files ,I try to re-encode by specifing same bit-rate sample-rate etc for the intro and the file but still having the same problem.I try different commands but nothing works fine , so I don't know what to do.
    1. Could you please give me a command to re-encode both of them to mp4 and will work fine?
    2. Is there any option to re-encode only one file, according to the other one settings? which command should I use?
    files infos(for example):
    file 1-
    Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'c:\tests\vid\intro.mp4':
    Metadata:
    major_brand : mp42
    minor_version : 0
    compatible_brands: mp42mp41
    creation_time : 2016-05-16 07:38:50
    Duration: 00:00:11.05, start: 0.000000, bitrate: 9247 kb/s
    Stream #0:0(eng): Video: h264 (Main) (avc1 / 0x31637661), yuv420p(tv, smpte170m), 848x480, 8941 kb/s, 29.97 fps, 29.97 tbr, 30k tbn, 59.94 tbc (default)
    Metadata:
    handler_name : Alias Data Handler
    Stream #0:1(eng): Audio: aac (mp4a / 0x6134706D), 48000 Hz, stereo, fltp, 317 kb/s (default)
    Metadata:
    file 2-
    Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'c:\tests\vid\vid.mp4':
    Metadata:
    major_brand : isom
    minor_version : 512
    compatible_brands: isomiso2avc1mp41
    encoder : Lavf55.31.100
    Duration: 00:05:37.97, start: 0.000000, bitrate: 2116 kb/s
    Stream #0:0(und): Video: h264 (Constrained Baseline) (avc1 / 0x31637661), yuv420p, 1280x720, 2052 kb/s, 29.97 fps, 29.97 tbr, 16k tbn, 59.94 tbc (default)
    Metadata:
    handler_name : VideoHandler
    Stream #0:1(und): Audio: aac (mp4a / 0x6134706D), 48000 Hz, stereo, fltp, 56 kb/s (default)
    Metadata:
    handler_name : SoundHandler
    Have you tried join with something else? Like mp4box or avidemux?
  3. Originally Posted by Baldrick View Post
    it didn't work for me..I still had problems with video , audio
    Try just reconvert the audio. Use exact same settings with for avidemux, under video choose copy.
    Or did you try that?
    Aug 2013
    Central Germany
    File 1 appears to be Main Profile AVC with LC-AAC, file 2 instead Baseline AVC with HE-AAC. Furthermore, they have different resolutions (848x480 / 1280x720). Simply concatenating both will confuse players at the joint. At least one of them will have to be recoded to the attributes of the other.
  6. Originally Posted by LigH.de View Post
    Is there any way to re-encoded one file(intro) to the same attributes as the other one and doing it by batch( I have multiple files and don't want to do it manually)? what do you mean by render only audio?
    Aug 2013
    Central Germany
    AFAIK, no, you have to manually discover the attributes of one file and set up your video and audio encoders accordingly.
    Why do you "need" an intro for so many different formats, anyway? Just for bragging ("I have made fire!") with ... let's say, "re-releases"?
