Hi,
thanks you for your help and i'm sorry for my bad english.
This is my problem. I need to extract Forced sub from a srt file with regular sub. The forced line star with "{\an8} (8 or other number) or the text is uppercase (like this UPPER). I'm trying with subtitle edit without result. The best way i try is:
in subtitle edit ---> tools ---> multiple replace
replace {\an with ****
than i chose regular expression and replace [A-Z]{2,} (that find the line where there are uppercase characters) whit nothing.
In this way i found the lines with forced subs and than i manually isolate those.
Is there any simple way to do this?
Thanks you.
Nope.
If you can't find a forced subtitle online for your movie.
How to extract subtitles from a Blu-ray and convert to srt or sub/idx
By Baldrick in forum User guidesReplies: 35Last Post: 6th Dec 2021, 07:00 -
Getting .srt forced subtitles to work on .mp4 in WMP 12 (Windows 8.1)
By dianatro in forum Newbie / General discussionsReplies: 2Last Post: 8th Jul 2015, 05:51 -
Extract SRT From MKV
By Valentin in forum MacReplies: 4Last Post: 12th Sep 2014, 20:14 -
How to extract .srt from mkv file
By Wooody in forum SubtitleReplies: 13Last Post: 18th Oct 2012, 05:43 -
Batch extract srt from multiple Mkv's?
By gosa in forum MacReplies: 59Last Post: 21st Apr 2012, 17:30
