G’day all.
I have finally solved the reboot problem.
After testing and failing all tests, the PC kept rebooting. At first it loaded windows OK, but it rebooted shortly after while I tried to open an application or Internet. In the end starting damping memory, blue screen.
I notice the start button sprang back out very slowly, I compared with another PC exactly the same and the start button sprang out swiftly. I removed the front panel and removed the switch from the panel and immersed in nail polish remover and washed it for a few minutes in it. When the pusher moved freely and fast in and out, re assembled the switch and front panel.
I had to re install the HDD image again as it had been corrupted.
It’s been three days that has not rebooted, by itself.
I am very grateful for the help and tips you gave me. I have learned a few more tricks.
Thanks to all.
Kind Regards
John![]()
Glad to read that.
But do you really need to start a new topic ? -
I've got to admit, I find that a bit funny.
Don't take that as a lack of empathy. Quite the opposite, in fact. The problem being in the last place you'd look.... that's the sort of thing that tends to happen to me.
Play random section from random movies in VLC?
By Gibson's Squares in forum ProgrammingReplies: 26Last Post: 30th Mar 2018, 17:51 -
Random reboot with no warning. HELP!
By jollyjohn in forum ComputerReplies: 17Last Post: 4th May 2016, 13:09 -
Laptop Will Not Reboot
By Teac23 in forum ComputerReplies: 18Last Post: 15th Jun 2014, 13:15 -
Windows System 32 pops up on PC reboot---WHY?
By will7370 in forum ComputerReplies: 1Last Post: 14th Feb 2014, 11:37 -
Playing Videos Makes PC Reboot
By jeanpave in forum Software PlayingReplies: 22Last Post: 5th Jan 2014, 01:44
