Hi, i'm using StaxRip with my GTX 970 and i want to know what is the best configuration to make a lossless mkv file with HEVC x265 codec.
Thanks.
If your source is something other than x265 and you're converting to x265, then it's not a lossless conversion. Maybe it'll be a good conversion; maybe you won't be able to tell the difference, but it won't be lossless.
If your video is already in x265 (which it isn't, if the source is a Blu-Ray disc), then you don't need StaxRip. You just have to mux into an MKV.
And if you understand a conversion into a lossy codec is never 'lossless', then someone else can give you some settings to use within StaxRip.
Sony BDP S1500 bluray player does not play .MKV file or burned bluray DVD
By theguy22 in forum Newbie / General discussionsReplies: 4Last Post: 28th Dec 2015, 18:10 -
HEVC MKV to mp4?
By gott4 in forum Video ConversionReplies: 8Last Post: 9th Oct 2015, 08:49 -
Create Bluray (MKV->Bluray) with custom menu
By ThaDraGun in forum Authoring (Blu-ray)Replies: 1Last Post: 17th Aug 2015, 20:52 -
Samsung TS (HEVC) into MKV
By Camboui in forum Newbie / General discussionsReplies: 7Last Post: 14th Aug 2014, 14:31 -
Did they ever make a bluray disc changer or a bluray/vhs combo?
By yoda313 in forum Off topicReplies: 4Last Post: 28th Mar 2013, 17:03
