Hi all,
Me and my friend are making a home made movie, but we have a slight issue with one of our camcorders. Basically the recorded footage, we can't seem to remove the horizontal fuzzyness that you get from the capture, basic deinterlacing tools weve tried, but they either end up motion blurring during moving scenes or they just fail to work. I am familiar with deinterlacing with Avisynth, and able to do that with dvds, but can anyone guide me step by step how I fix it on this particular footage recorded from a camcorder?
Thanks in advance.
Hits
Every 6th frame is identical to every fifth. Looks like you shot at 25/50 and captured or converted to 29.97/59.94. Maybe you have the field order inverted as well, but I would work on maintaining the original frame rate first.
Oh yea, you're right the file is 29.970 fps, ok let me double check on this! Thank you.
Deinterlacing Issue
By Chaube22 in forum DVD RippingReplies: 8Last Post: 7th Nov 2014, 04:17 -
Deinterlacing
By SameSelf in forum Video ConversionReplies: 24Last Post: 15th Aug 2014, 10:09 -
MeGUI Avisynth issue on DVD ripping after Deinterlacing
By Mastur in forum DVD RippingReplies: 8Last Post: 16th Nov 2012, 05:27 -
Deinterlacing
By mmbwdpnz in forum Newbie / General discussionsReplies: 7Last Post: 2nd Nov 2012, 17:52 -
deinterlacing
By encodingmonkey in forum ffmpegX general discussionReplies: 5Last Post: 25th Jul 2012, 14:27
