I have successfully captured a 12 min video from my Hi-8 camera... Im using ATI All in wonder 7500 radeon. I did not drop any frames at all using trial version of Ulead's Movie Studio 6. Captured the movie on 352 x 240 ... when i created the VCD disk and played in on my home theater system i noticed that the quality is not good.. its is very pixelly i may say....
I need some advice on what to do with this situation.. Im just playing around with this movie clip till i get a good result.... should i capture it in a higher reslution?
I have adobe premier 6.02 but not really familiar on how to use it .. should i capture it using that software ?
need advice ..
thanks
Results 1 to 1 of 1
901102 - best VCD quality
By hamidi2 in forum Video ConversionReplies: 32Last Post: 26th Aug 2018, 18:49 -
Convert .avi movie files to vcd or dvd without loosing picture quality
By akakiami in forum Video ConversionReplies: 8Last Post: 8th May 2010, 17:01 -
Movie quality for VCD
By dilanalex in forum Newbie / General discussionsReplies: 12Last Post: 21st Apr 2009, 01:42 -
How to add Watermark to VCD MPEG1 without Quality Loss?
By shebi in forum Authoring (VCD/SVCD)Replies: 3Last Post: 15th Apr 2009, 13:13 -
&fmt=18 does not give the same quality as playing by "high quality
By arminio in forum Video Streaming DownloadingReplies: 2Last Post: 9th Feb 2009, 18:33
