Results 1 to 16 of 16
  1. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    The brilliant team at Microsoft has two names for their browser. Bing and Edge. I guess one team doesn't know about the other.
    Isn't bing the search engine?
  3. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    I'm not sure. So they split IE into two products?
    Oh, I get it. Bing is the censorship product for developers. Can filter results for family oriented applications.
  4. Mod Neophyte redwudz's Avatar
    USA
    Cortana is sort of a browser, along with Edge. Bing is still a search engine.
    I've blocked and turned all of them off in Windows 10.
    They are all eager to send all your info to MS to help you.
  5. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    What sparked up my curiosity is that I'm using a Windows Store app, PicCollage, which uses Bing as it's search engine, and it doesn't return results for searches that contain words like "fart".
    But if I go to "bing.com", there are plenty of results for "fart".
    P.S. I'm pro-MS, I have a Surface Pro 4. I really want MS to make a comeback.
  6. DECEASED
    Jun 2009
    Heaven
    Neither. I will keep using Windows 7 "till the end of time"
  7. Budwzr, you going to change your name to america too?
    http://www.usatoday.com/story/money/nation-now/2016/05/10/budweiser-renames-cans-beer-...usch/84176886/
    I'm part of the MS ecosystem. They have a pretty good family system. It sends me all the stuff does on his win10 laptop, in a weekly email. Pretty cool
    I use Edge browser most of the time, as it's as fast or faster than Chrome. I don't use Cortana that much
    Originally Posted by jagabo
  8. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    Heck no, I don't even drink Bud any more. I'm a 4Loko man now. And I like those 5 liter wine boxes too.
  9. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    I'm a Linux user at home, and a Windows 7 user at work.
    I'll with with 7 until forced to update. What I've seen of Windows 10 hasn't convinced me I need to upgrade.
  10. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    Windows 8 was a real mess, but 10 clearly separates the Apps from the Applications.
    I think the main reason to upgrade is the security. Win10 should be much more secure. Don't forget, you still want to do banking over IP.
    Also, as I get into my golden years I kind of like the simplicity of using a simple App to make fun "postcards" to send around to friends and family, instead of busting out with a big program.
    As our Fams migrate more and more, you have to become "Mobile Grandpa" to stay connected. They don't care for the standard old fart style any more. Hahaha. Neither do I, although I'm semi-retired. Making cute visuals on a larger screened laptop has its advantages. My eyeballs get burned out using a phone to do everything.
    I use OneDrive to create a bridge between devices, and it works pretty well. I have an Asus laptop, Surface Pro tablet, and Nexus 6, and they all share together.
    You have to fool with it for a few weeks, but eventually it will come as second nature, just like the beloved Windows 7.
  11. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    Originally Posted by stiltman View Post
    ... I don't use Cortana that much
    Yeah, it's really dorky. But I do like the "Hello Google" thingy. Good for when you're driving, to get navigation going right away.
  12. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    Another reason to upgrade to Win10 is to go ahead and get started using/getting used to, your touchscreen/Pen options. The cutting edge pen tools are coming out as Apps.
    You like to annotate/draw on PDF files? Win10 has the apps for that.
    As far as Cloud storage, I doubt there's any better service than OneDrive. OneDrive is the means by which MS can penetrate multiple OS's. OneDrive is Microsoft's strongest tool to get integrated everywhere, and it works flawlessly. Not like Apple Cloud, that the user can't even see a directory view of their own files.
    Win10, as opposed to Win 7, can take advantage of OneDrive's advanced features.
    Aug 2006
    I don't plan to switch my main PC to Windows 10 (Pro) until I build a new one because I'll need to buy a new license for it. My current PC will be my "new" HTPC running the Windows 8.1 Pro with Media Center license that I already have. The laptop will also continue running Windows 8.1. Support for Windows 8.1 is not scheduled to end until 2023. The laptop and HTPC could both be dead by then.
  14. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    I don't have a pen or a touchscreen, so no need there.
    Only seldom, but when I do I simply use Acrobat.
    How would you say it compares to Dropbox, which is what I currently use?
  15. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    I used DropBox myself, for a while. I have no complaints.
    Thing is, Microsoft has a lot to lose if their cloud service hiccups. That means they are probably extra careful not to commit a faux paux.
  16. Member Thintich's Avatar
    Aug 2016
    Pittsburgh, PA
    better Brake!
