I have tried for several days to avail, so I figured I would tap our combined thoughts....
I have purchased several "previously-viewed" videos from Blockbuster (Evil Empire) with the intent of creating a digital movie library on VCD. The oldest (60's-) videos capture great, but the newer ones have that shit Macrovisio in them. As far as I am aware, since I purchased the videos, I can create a personal use copy in any VCD, no? Anyway, the question at hand is: Is there anyway around VHS's macrovision encoding using a Composite input signal with an AIW 128 16MB???? I've tried ATI's shit capture program as well as VirtualDUB... Is this just a hardware thing that cannot be overcome? Is personal use law dead? PLEASE ADVISE....
use the 4.12.6292 ATI drivers (unless you're in win2K). go search http://www.rage3d.com forums for a link about '30 second patch'. this still stop the looping of frames at least some of the time. you still get some brightness flickering in AVI mode, almost none direct to MPEG. use MMC 7.1 to capture to SVCD bitrates with motion estimation as high as you can go without losing frames.
Ok, but what if I AM using win2k (for al of it's numerous performance advantages)? Is there a patch for driver version 5.13.1.192? Thank you very much for the idea!
it might work for that one too. i think that's the one i'm running (i'm dual booting ME/2K). capture is better in 9x than 2K because you can use real VFW drivers.
No luck finding that link on rage3d forums... you have direct link or another source?
it's still right there...
http://www.rage3d.com/board/showthread.php?s=&threadid=20732
Capturing VHS with Diamond AIW HD 3650PM
By justin81 in forum Capturing and VCRReplies: 1Last Post: 13th Jul 2009, 14:15 -
ATI AIW 128 720x480 mpeg captures have horizontal tearing
By cybertheque in forum Capturing and VCRReplies: 16Last Post: 17th Sep 2008, 20:53 -
Populating empty ATI VIP / AMC feature header on AIW Rage 128 Pro
By cybertheque in forum Capturing and VCRReplies: 3Last Post: 14th Sep 2008, 15:36 -
Capturing issue
By Jensen in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 21st Dec 2007, 02:38 -
ATI AIW 9800 audio issue
By saggitarius in forum Capturing and VCRReplies: 1Last Post: 27th Jul 2007, 15:17
