Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
  1. I need help enabling the advanced tab in VidCoder, and I want to know how to convert to 10bit with it.
    Aug 2013
    Central Germany
    10 bit ... what? AVC? HEVC? VP9?
    If it doesn't come bundled with an encoder supporting 10 bit component depth, you can't use it for this purpose. And I doubt it does, its target are quick and simple conversions. Video formats with 10 bit depth are not very compatible to consumer playback devices, you may need tools supporting semi-professional purposes by including encoders with advanced features, like e.g. MeGUI / StaxRip / Hybrid ...
    Regarding an "Advanced" tab: VidCoder Tutorial page 1 from 2011; is this tab not visible to you?
  3. Originally Posted by LigH.de View Post
    Here's a picture.
    http://imgur.com/Ghcrz3I
    Nov 2003
    West Texas
    Handbrake has a Main10 H265 Profile. You might want to switch to it for this type of encode.
    Aug 2010
    San Francisco, California
    You could also try the latest beta of VidCoder (2.28) which may offer 10-bit in the codec picker. Be advised, however, that this version of VidCoder uses a lower-quality AAC (audio) encoder due to license issues.
  6. Originally Posted by Kerry56 View Post
    Ok, thanks!
  7. Like LigH said the default HandBrake package doesn't come with the necessary libraries for 10 bit encoding. See: https://forum.handbrake.fr/viewtopic.php?f=11&t=34165
