I have acquired a few WMV files over the years in anticipation that one day I might be able to do something with them. I usually avoid WMV like the plague because they're generally worse quality than anything else and they're totally incompatible with every hardware-based piece of equipment I have for playing them.
That said, I see an opportunity now to convert them to MP4 format using Handbrake so I can at last watch them in comfort (ie, not perched at my computer). A problem arises though with many of them where I'm assuming they have bad frames or are otherwise slightly corrupted somehow such that Handbrake has difficulty decoding them. There is no evidence of this in playing them in MPC-HC on the computer, but when trying to convert them, handbrake will give up and quit them mid-encode with no error message at all. It's as if handbrake just thinks it's come to the end of the file and finishes normally.
Is there any software that can scan WMV files and report bad frames or other non-compliant stream errors and perhaps cut out those bad sections? Kind of like VirtualDub error mode, but I've tried that and it finds nothing wrong.
Results 1 to 10 of 10
Yep. It's always good to try another converter. Like Xmedia Recode or even VLC Media Player(under Media->Convert/Stream)
AsfbinWin didn't work, but thanks for the suggestion. Handbrake just exited at the same point with the resultant ASF as it did with the original WMV. I'm trying ShotCut now instead.
Edit: Unfortunately Shotcut is complete unfinished rubbish that just crashes constantly while running and even when trying to install it or reinstall it or even remove it. It's almost worse than a virus!Last edited by DRP; 11th May 2016 at 04:21.
MKVToolnix doesn't support ASF/WMV containers
Sorry then. For me it works without any problem. If only you could upload your broken wmv. I have similar problem with other software but not with this one.
My mistake. I actually succesfully used:doesn't support ASF/WMV containers
ffmpeg -i Video.wmv -c copy Video.mkv
for a wmv made in Windows Movie Maker. -
All AsfTool repairs made no difference at all to Handbrake's handling of the file however XMediaRecode seems to be able to encode without aborting midway so far. Thanks for the suggestions. I shall just use XMediaRecode on problematic files instead of Handbrake.
What can I use to cut 5 frames?
By efc1978 in forum EditingReplies: 46Last Post: 16th Aug 2015, 23:13 -
Video check for lost frames
By kasda in forum Newbie / General discussionsReplies: 0Last Post: 17th May 2014, 12:31 -
Ts and Mkv files - bad frames - repair help?
By ttepper27 in forum EditingReplies: 0Last Post: 3rd Apr 2013, 03:08 -
Searching Command-LIne Utility to check video file for some errors...
By steveallen in forum Newbie / General discussionsReplies: 0Last Post: 25th Aug 2012, 07:40 -
how would I check for errors in multiple videos??
By bidomo in forum Video ConversionReplies: 6Last Post: 6th Jun 2011, 21:13
