Have begun converting dozens of VHS and 8mm camcorder tapes to digital. I am using a Canopus ADVC-55 converter, RCA in / Firewire out. This works great and creates a 26.3GB .avi file for every 2 hour tape! There is no way to change the output format. Since I don't have 10TB of storage, what is going to be my best format to compress/convert this avi file to, while keeping as much quality as possible! I will be viewing the files mostly on a PC connected to a HDTV or PLEX to a tablet/phone. Thanks!
I use MKV (H.264/AC-3) format for most all my conversions. You might try Vidcoder. It has some presets for phone and can also do high quality for archiving.
And it's easy to use.
I use it for DVD conversions and they go from about a 8 GB DVD down to about a 2 GB MKV and still look good.
I've been using it for BD>MKV and that shrinks them down from about 30 GB to about 8 GB.
I haven't tried it for DV as my ADVC-100 died a while ago.
I used a different box and converted about 150 VHS tapes to MKV.
DV's a great format for editing, but not so good for compact storage.
But try a few programs. Others here may also give better advice.
And welcome to our forums.
Newb here. Having trouble converting VHS to DVD on Panasonic recorder
By CocoXO in forum Newbie / General discussionsReplies: 3Last Post: 10th Mar 2016, 12:54 -
Help, advice needed please. VHS to digital video.
By chey in forum Video ConversionReplies: 3Last Post: 2nd Mar 2015, 16:35 -
Advice needed for converting family VHS tapes to digital
By jadoggin in forum Capturing and VCRReplies: 128Last Post: 18th Nov 2014, 19:02 -
Advice needed for proper VHS to Digital format using ADVC-100
By joeman in forum Capturing and VCRReplies: 5Last Post: 3rd Nov 2014, 20:00 -
Converting VHS to digital, VHS tracking problems?
By ReedJohansson in forum Newbie / General discussionsReplies: 3Last Post: 23rd Jan 2012, 10:54
