Hi everyone
This may be a silly question, but i wanted to ask and put my mind at rest.
I have a simple device which allows for upto 5 analog connections (including s-video). I can then flick a switch on the device to control which one is then output to my tv.
Does this kind of device (which is just re-routing a signal) affect quality.
It can. Poor shielding, bad connections, wrong impedance, all can effect the analog signal.
Stay with better shielded and short cables 6 to 12inch for peace of mind, Try to avoid switches, passthroughs, splitters, adapters, couplers ...etc
If you're looking for the best possible signal, you'll have to get a powered switch with a built-in amplifer since even the best non-powered switches have some loss due to the factors jagabo stated.
Howver given the comparatively low quality of s-video (below component and HDMI) and limited quality of the sources (probably gaming consoles and VCRs), the additional quality of a powered switch won't be noticible and not worth the cost (they are expensive $$ and hard to find, especially with 5 or more inputs). -
Although there may be measurable losses with any switch, in real world viewing you won't notice any difference with a decent one, especially with standard definition video.
hard drive problems, affect blurays
By krohm in forum Blu-ray RippingReplies: 5Last Post: 6th Sep 2015, 22:46 -
Hardware Accelerating Decoding Affect On Quality?
By hogger129 in forum Video ConversionReplies: 3Last Post: 25th Apr 2015, 03:13 -
Does X264 tune affect rendering time?
By lonrot in forum Video ConversionReplies: 4Last Post: 2nd Jul 2014, 00:42 -
Make SubtitleCreator affect more than one title?
By Zestanor in forum SubtitleReplies: 3Last Post: 4th Sep 2012, 02:55 -
Does packaging format of videos affect rendering quality?
By MarcMiller in forum Newbie / General discussionsReplies: 6Last Post: 1st Nov 2011, 16:27
