I've never had this issue before using the same encoding settings. I'm using Bd-Rebuilder 50.11 and the particular movie is Se7en (VC-1) and it stutters just slightly, the audio seems unaffected. I know it's the encoding/encoder because the bluray itself plays fine on the same system then after the encode it stutters using the same playback methods.
I've also burned to blu-ray and played on ps3 and ps4 and still stutters. I tried encoding the same way again to make sure it wasn't a fluke and the problem remained. I've always used the High Speed option & ABR due to having a slower 'puter. But this has never been a problem just takes longer. My target size is BD-25 if that matters.
Here's the system settings:
[05/09/16] Checking System Settings
- BD-Rebuilder v0.50.11
- Windows Version: 6.1 [7600]
- Working Path Free Space: 96.73GB
- AVISYNTH Version: 2.5.7.0, Ok
- LAVFILTERS: Ok
- AnyDVD settings check: Ok.
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
- FRIMEncode: Ok
- FRIMDecode: Ok
[05/09/16] Systems Settings Check complete
	Try switching frame serve to DS from LAVF. DS seems to handle VC1 better.
	Assuming BD-Rebuilder always uses Avisynth...
 2.5.7 is outdatedAVISYNTH Version: 2.5.7.0, Ok Besides, the Avisynth script itself may be the source of the problem Besides, the Avisynth script itself may be the source of the problem
	Going try bd rebuilder 50.14 and avisynth 2.60 now...
 (sorry double post used to having delete/merge permissions)
	The new Bd Rebuilder and avi synth yielded the same results, however doing the opposite of what wulf109 said and it seems to have worked.
  [SOLVED] 720p60 video stutters when playingBy white_snake in forum Software PlayingReplies: 31Last Post: 20th Feb 2016, 10:55
  BD Rebuilder - Blacks becomes washed out/brighter after encode [SOLVED]By rk- in forum Blu-ray RippingReplies: 7Last Post: 2nd Sep 2015, 19:18
  Encode only Bonus material in DVD RebuilderBy walruss in forum DVD RippingReplies: 9Last Post: 25th Jul 2015, 18:08
  Video stutters after trimmingBy Freodon in forum EditingReplies: 120Last Post: 9th Jan 2015, 09:32
  Sony Vegas 12 stutters when Xvid video is used?By CursedLemon in forum EditingReplies: 4Last Post: 18th May 2014, 10:39
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
