Can someone please point me to where the setup configurations are for frameserving in VirtualDub v1.10.4? This used to be via a small program in the installation folder called Auxsetup, but I can't find it anymore. I'm using VDub v1.10.4 x64 in W7 and am looking to frameserve into Handbrake.
Cheers
Same place as usual under File > Start frame server
For 64bit before you launch the program you should apply frameserver64.reg details located in the install folder
64bit does not generally contain Auxsetup, depending on where the install folder was downloaded from may, only 32bit installs include it. -
Any ffmpeg based converter (Handbrake is one of them) will try to read AVIs with own splitters and decoders (libavformats, libavcodecs). Using any frameserver like AviSynth or VDF instead requires that applications let Windows read and decode an AVI with VfW codecs, which ffmpeg usually does not support.
there is a way how to get frame server into Handbrake, using AVFS and Pismo File Mount for those who want to use Handbrake for encoding,
some workflow is described here , it how to export from Vegas to Handbrake by script, so modified workflow could be used to load that VirtualDub frame server
Frameserving from Vdub to TMPG VMW5
By DVWannaB in forum Video ConversionReplies: 8Last Post: 17th Feb 2015, 14:00 -
Conversion settings for Wondershare Converter; export settings for Pinnacle
By avz10 in forum Video ConversionReplies: 1Last Post: 19th Jul 2014, 12:41 -
x264: are ME settings conflictory to SUBME settings?
By deadrats in forum Video ConversionReplies: 1Last Post: 13th Dec 2012, 18:54 -
Problem Installing Vdub with Mpeg Plugin; How to use VDub in Pinnacle St
By avz10 in forum EditingReplies: 1Last Post: 15th May 2012, 04:40 -
VFW ffdshow Settings to Edit flv in Vdub
By kaskaļ in forum Newbie / General discussionsReplies: 15Last Post: 1st Jun 2011, 12:40
