I am trying to convert a 1280x 720 video to 740 x 416. I notice after being convert using both handbrake and video coder, there are some segments of the video where the audio pitch is higher or softer. Do you know how I can get the audio to be exactly the same as the original file? Is this a setting issue? When I use handbrake, I chose keep aspect ratio and anarmorphic as none.
Maybe it could be if you choose variable frame rate, which is set up by default. Try constant frame rate. Not sure if that helps.
Bernix -
How the video is sized, processed or re-encoded should have NO bearing on the audio. If it does, you have some major settings wrong.
Avoid the problem altogether by:
1. Making sure that whatever you do to the video, it doesn't change the framerate away from what the source was.
2. Demux the audio, save it & put it aside, do your video work, and then remux that original audio back in.
Video "static", audio changes pitch
By koberulz in forum Newbie / General discussionsReplies: 0Last Post: 7th Feb 2016, 14:46 -
Ripp/convert DVD for Youtube: Vidcoder, Handbrake, Media Coder Web Edition
By vabas in forum Video ConversionReplies: 3Last Post: 24th Aug 2014, 20:09 -
Solved:possible to automatically correct audio pitch and sync it with video
By Srivas in forum EditingReplies: 2Last Post: 4th Jul 2013, 14:49 -
Can I use Handbrake to convert a 1080p video clip to 1080i?
By jbitakis in forum Video ConversionReplies: 21Last Post: 27th Nov 2012, 17:57 -
Every video I make with Handbrake mkv has framerate of 90000 & wont convert
By Onceler2 in forum Video ConversionReplies: 7Last Post: 12th Sep 2011, 11:26
