Hi all .Could any one suggest some easy to use tools that allow me cut part of mp4 video without re encoding it(so original video quality is preserved)?(I look for a tool that has player and allow me visually mark start and end of video ). I have used ffmpeg but i need to input start and end time manually which is difficult some time to obtain!Thanks in advance.
Whether you can cut part of an mp4 without re-encoding is quite dependent not only on the tool used, but WHERE in the sequence the cuts are being made. If the cut is NOT on a keyframe (I-frame, IDR), you will ALWAYS have either a mis-timing (forced cut changed to elsewhere) or you will require re-encoding.
Without that knowledge, nobody can tell you for sure.
Scott -
Agree with Cornucopia. XmediaRecode is what I use to trim mp4's, MOV's, M2T's, TS's and so on. Make sure to cut on Key-Frames.
Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
Thanks for replies. racer-x could you tell me the steps that doesn't involve re encoding ? I don't know how to enlarge video player on filters/preview tab and how to save the the edited video ? Can't find the save as button!
Use mpc-hc for find the specific frame, then use MKVToolNix for cut/trim without re-encode. Btw, the output file is mkv. Just remux to mp4 using ffmpeg
How to easily convert a Blu-ray to MP4/M4V/MKV using free tools
By Baldrick in forum User guidesReplies: 18Last Post: 29th Mar 2018, 02:20 -
Free tools on Mac: Remux BDMV folder into mp4/mkv?
By TOMillr in forum Video ConversionReplies: 5Last Post: 18th Apr 2015, 05:45 -
Cut part out of MKV, without re-encoding?
By bagmand in forum EditingReplies: 2Last Post: 20th Feb 2015, 06:56 -
Looking for free BATCH 3gp to Mp4 conversion tools WITHOUT quality loss.
By c1steady in forum Video ConversionReplies: 2Last Post: 7th Aug 2012, 06:53 -
How do I cut out a part from a MP4 file
By Mickie in forum EditingReplies: 8Last Post: 11th Aug 2011, 08:01
