I have a CCTV camera mounted on a support structure where that structure vibrates at a constant 50Hz (mains frequency).
I cannot relocate the camera to a stable support structure.
Is there any way that I can apply a 50Hz filter to remove the vibration from the video clips? How to implement this?
If it's a CMOS CCTV camera, you're going to get more than x,y translation issues - you will get a "jello" wobble which is very difficult to fix properly
Posting a sample video might help -
Plus, the vibration cycle may not translate exactly to a simple x,y translation anyway, as there could be multiple levels of lag, dampening, harmonics, resonant frequencies, intermodulation. And the vibration probably would be in 3D space, so you have x, y, and z types of motion as well as possible rotational influences.
940729 - how to eliminate vibration?
By hamidi2 in forum Newbie / General discussionsReplies: 75Last Post: 6th Nov 2015, 15:26 -
Nokia Lumia OIS Jello / wobble due to motor vibration
By Mr. Aldi in forum RestorationReplies: 5Last Post: 22nd Mar 2015, 11:01 -
How to remove cloud picture noise that McTemporalDenoise can't remove?
By VideoFanatic in forum RestorationReplies: 9Last Post: 3rd Apr 2013, 17:18 -
Vibration causing images to go wierd
By woodlander in forum Capturing and VCRReplies: 11Last Post: 8th Jul 2012, 09:22 -
Does WD TV Live support both 60 and 50HZ?
By Bencuri in forum Media Center PC / MediaCentersReplies: 14Last Post: 21st May 2012, 20:50
