Hey I have a question on merging a blu ray video with Dvd audio. Year ago I brought a blu ray video Cold prey. The movie is subtitled. There is a dvd version that has dubbed english. How would I combine the dvd audio with the bluy ray video? (also keeping the audio in sync)
Use MakeMKV to rip DVD and BluRay to mkv. Then use Mkvtoolnix (GUI) to merge the tracks you want to combine. You may or may not have to change audio delay and/or video fps to make them match. If the cuts are different (i.e. like a director's cut vs. cinema cut) it becomes more difficult.
Thanks not sure how to handle it as there is a 4 minute difference between the 2 files.
Could be fps. The playtime is 1:37. The difference between 23.976 (NTSC BluRay) and 25 (PAL Norwegian DVD) is about 4% (about 4 min)
Change with Audascity -> Fillters -> Change speed
Merge two audio tracks from MP4 video
By cawekun in forum Video ConversionReplies: 7Last Post: 27th Apr 2018, 06:54 -
Cant merge mkv video and audio with mkvtoolnix?? any ideas?
By kjy in forum Newbie / General discussionsReplies: 5Last Post: 6th Jan 2016, 11:37 -
Merge MKV video and audio
By mlmiller707 in forum Newbie / General discussionsReplies: 1Last Post: 26th Nov 2015, 16:40 -
CLI to mux/merge MP4 video and AAC audio?
By RogerTango in forum Video ConversionReplies: 8Last Post: 13th May 2013, 15:43 -
AVI - audio remove, video split, music merge
By kj1983 in forum Newbie / General discussionsReplies: 1Last Post: 29th Apr 2012, 02:59
