  1. i am trying to to make a dvd-r video. it will only take vobs files so How do i creat them ? If some one can help that would be great. 8)
    May 2001
    You have to author your DVDs using an authoring program. This will properly "navulate" and multiplex the elementry streams (audio and video) into a .VOB file. Your DVD writer probably came with some bundled software and an authoring program was one of them (MyDVD, DVDit-LE, etc). Most (all?) of the bundled stuff is crap, but it will get the job done (although probably not to your satisfaction).
  3. i use Spruce DVD Maestro to author Mpeg to Vobs, easy to use
