    Feb 2008
    Portugal
    Where can I find my session cookies? Can we make a backup or copy of cookies, eliminate some and restore those that we want?
  2. Member DB83's Avatar
    Jul 2007
    There is no simple answer to your question.
    It depends both on your Operating System - is it still XP or something later ? AND your browser.
    I assume you also mean general/local cookies since 'Session Cookies' are usually stored on the server and not on the local machine ie your PC.
  3. DECEASED
    Jun 2009
    Heaven
    Seamonkey uses a file named "cookies.sqlite". The Presto-based versions of Opera used a file named "cookies4.dat".
    IIRC, the VERY-ancient versions of IE stored the cookies in plain-text files, one for each site visited
    Feb 2008
    Portugal
    The Operating System is Windows 7 and the browser is Mozilla Firefox.
  5. Mod Neophyte redwudz's Avatar
    USA
    In FF 44.0.1 try:
    Open 'Menu>Options>Privacy>History>Show Cookies'
    Feb 2008
    Portugal
    I did Tools>Options>Privacy but I didn't find any icon called History.
    But I succeed to find the list of cookies that only allows " Remove " but not " Save " that makes possible to eliminate all the cookies and reload the desired.
    Sep 2003
    Northern California
    You might check out CCleaner.
    OPTIONS > COOKIES ......... will bring up 2 lists: Cookies on computer & Cookies to keep.
    Hope this helps.
    Losing one's sense of humor....
    is nothing to laugh at.
  8. I'm a Super Moderator johns0's Avatar
    canada
    Ccleaner=crap.
