  1. Hi guys I need little help
    I tried to follow following guidance
    https://forum.videohelp.com/threads/304395-DV-to-H-264-conversion-with-emphasis-on-quality
    but when opening the avs file in virtual dub (64 version) I got error
    Is it too old soft to us it on win 8.1 or may be you can guid me to some other good quality converter for DV-AVI to ...
    Thanks in advance
  2. TempGaussMC is obsolete, it was upgraded to QTGMC. Get together all new or updated dlls, perhaps from here and you can use script like this as well, something like this:
    Avisource("DV.avi")
    Import("C:\tools\QTGMC 32-bit Plugins\Avisynth 32-bit Plugins\QTGMC-3.32.avsi")
    LoadPlugin("C:\tools\QTGMC 32-bit Plugins\Avisynth 32-bit Plugins\mvtools2.dll")
    LoadPlugin("C:\tools\QTGMC 32-bit Plugins\Avisynth 32-bit Plugins\RemoveGrainSSE2.dll")
    LoadPlugin("C:\ools\QTGMC 32-bit Plugins\Avisynth 32-bit Plugins\RepairSSE2.dll")
    LoadPlugin("C:\tools\QTGMC 32-bit Plugins\Avisynth 32-bit Plugins\mt_masktools-25.dll")
    LoadPlugin("C:\tools\QTGMC 32-bit Plugins\Avisynth 32-bit Plugins\nnedi3.dll")
    LoadPlugin("C:\tools\QTGMC 32-bit Plugins\Avisynth 32-bit Plugins\dfttest.dll")
    LoadPlugin("C:\tools\QTGMC 32-bit Plugins\Avisynth 32-bit Plugins\EEDI2.dll")
    LoadPlugin("C:\tools\QTGMC 32-bit Plugins\Avisynth 32-bit Plugins\FFT3DFilter.dll")
    LoadPlugin("C:\tools\QTGMC 32-bit Plugins\Avisynth 32-bit Plugins\nnedi.dll")
    LoadPlugin("C:\tools\QTGMC 32-bit Plugins\Avisynth 32-bit Plugins\nnedi2.dll")
    LoadPlugin("C:\tools\QTGMC 32-bit Plugins\Avisynth 32-bit Plugins\SSE2Tools.dll")
    LoadPlugin("C:\tools\QTGMC 32-bit Plugins\Avisynth 32-bit Plugins\VerticalCleanerSSE2.dll")
    LoadPlugin("C:\tools\QTGMC 32-bit Plugins\Avisynth 32-bit Plugins\AddGrainC.dll")
    Load_Stdcall_plugin("C:\Program Files (x86)\AviSynth 2.5\plugins\yadif.dll")
    assumeBFF()
    QTGMC(Preset="slow")
    LanczosResize(640,480) #4:3 NTSC, for 16:9 it would be different
    Or put those DLL's into Avisynth plugin folder.
    Final resize to 4:3 square pixel is a thing to debate, ussually heated debates. Could be 720x540 (with vertical resolution change) or you just leave it as is 720x480 (NTSC) or 720x576 (PAL) but while encoding you'd have to give H.264 stream aspect ratio (x264 names it SAR).
  3. Use VirtualDub 32 bit to open AviSynth 32 bit.
  4. Originally Posted by sneaker View Post
    Well, the 32bit version is also giving errors
  5. Is there any place where I can download the whole package of dll-s. The mentioned thread seems to have brocken links
    Avisource("DV.avi")
    assumeBFF()
  6. Originally Posted by martin. View Post
    Yeah, but the problem is no longer mismatched programs. Install a DV-AVI codec, one such as Cedocida.
    Try here:
    http://avisynth.nl/index.php/QTGMC
  7. [QUOTE=manono;2444246]
    Gets funny already
    When trying to install Cedocida
    But it worked anyway
    Aug 2013
    Central Germany
    To grab only the currently active window, press Alt+PrtScr; no more cropping.
