This is strange. Dou you mix it with any other plugins or extract the archive into clean directory?
I just realized the error message can be from different plugin.
Please show screenshots with driver dropdown expanded
Results 61 to 90 of 189
Where did you get the archive and which version?
if you unpack VirtualDub_FilterMod_40121.zip from sourceforge, the "ffmpeg_default" driver name has long gone (since this new "Open video" dialog). -
Yes, some files must be removed, not good idea to overwrite directory. Remove cch_input.vdf for sure.
[+] frames are not real, instead they show copy of previous good frame.
The conditions when this happens are quite loose, maybe damaged file, maybe vfr to cfr conversion or other timestamp mismatch.
If you believe it is wrong give me a sample file. -
I just wanted to confirm that after deleting "VirtualDub.org" key from the registry and extracting VirtualDub FilterMod to a clean directory it worked, thank you.
No I was just curious. There were only 2 frames like this in the end of a video file.
Is it possible to output h264 stream without muxing it into any container ? -
In this case most likely the reason is inexact estimation of the number of frames from total duration. This procedure is inexact without brute-force counting all frames.
I just tried, and luckily it works
In the output select "any format by ffmpeg" and type filename extension ".h264" -> ffmpeg understands to write raw stream. -
Hi shekh.
When playing through a video or using CTRL+G I constantly get the "Out of memory" error. This didn't happen with the older versions. Any idea as to what might be the problem ? -
What is shown at the bottom of file->information window? One possibility is too big cache, in that case you will see some big memory usage numbers.
Also tell me are you running x86 or x64, how much physical memory you have and do you have page file enabled (how big). -
What is shown at the bottom of file->information window?The memory usage in Task Manager is 160 MB.Code:
Seeking: index present Memory cache: 480 frames / 1209M reserved, 100% used Frames decoded: 1253
Win 7 SP1 x64 with 4 GB of RAM and 4 GB page file.Also tell me are you running x86 or x64, how much physical memory you have and do you have page file enabled (how big). -
It is still not quite clear what happens in your case. Even if 1200M is taken for cache it is still not the end of world.
Maybe it can help now if you increase page file limit. In the next version (coming soon) I will provide options for cache size.
What exactly the error message says? Are you adding any filters or anything special?
Looks like you run virtualdub.exe (x86 aka 32bit) because 160 MB is so small. 32bit version of input driver uses shared memory, it is accounted on behalf of some system process instead of virtualdub.exe, so you better watch total used memory. -
Exactly says "Out of memory"What exactly the error message says?
Nothing, I'm just playing the input pane.Are you adding any filters or anything special?
Yeah, I was only using the 32bit version so I tried the 64bit version for the first time today and the memory usage reported by the Task Manager was 570 MB and there were no more errors. Now something odd has happened, even when using the 32bit version the memory usage is around 570 MB and there have been no more errors up to now.Looks like you run virtualdub.exe (x86 aka 32bit) because 160 MB is so small. 32bit version of input driver uses shared memory, it is accounted on behalf of some system process instead of virtualdub.exe, so you better watch total used memory. -
But are you playing the same file as before or different file? Because memory usage is different for each file.
Can I have multiple segments of a video under File>Export>Stream Copy? How do I mark the segments and get them saved? At present, I am able to get only one segment.
No, does not append segments.
https://sourceforge.net/p/vdfiltermod/wiki/direct_copy/ -
Veedub64.exe = 64 bit (can use more memory)
VirtualDub.exe = 32 bit (more compatible with legacy plugins, if you want them) -
OK, thanks. Just tried opening a vapoursynth script but I get error - AVI Import Filter Error: Unknown
Did you install VapourSynth? This message is typically because of installation problems.
I used the portable version of vapoursynth. The Vapoursynth Editor is working fine after I entered the vapoursynth paths in it's settings, but I wanted to try out your application. How do I tell your app that VS is installed? Should I just try to register vapoursynth.dll?
DONT LET VIRTUALDUB TO DIE PLEASE
thanks you all this is the first program i used from the days i convered divx avi's thanks -
Hello shekh and thank you for VirtualDub2
I record from live wildlife webcams. I edit clips from very long recordings with Freemake Video Converter (because it has a big interface and is very simple to use, I won't go into its many shortcomings!) and upload to YouTube for interested parties in wildlife forums.
Many of the cams are low-quality, and my software is not the best, so I used to use YouTube's "Enhancements" but they have now been withdrawn. That's why I came to install VirtualDub2, and it's doing a great job considering my low level of expertise. The GUI is a mess on my 4K display (as with many programs) so I changed the compatibility properties and at least can now see the controls
Input files are mp4, VD2 outputs avi. That's fine.
I use x264 10-bit compression (guessing from Google that its size/quality ratio was best for me) and:
Brightness/contrast
Sharpen
Saturation (found in 6-axis color correction)
But I haven't found an equivalent to YouTube's "Fill Light", which was brilliant for brightening dark scenes without adding glare - especially useful for nighttime scenes with poor IR light. Should I be able to find a similar filter in VirtualDub2?
I hope there's not too much info here, but thought it might help to know the simple sort of "work" I do
How can I load virtualdub plugins in AvsPmod
By TeNSoR in forum Newbie / General discussionsReplies: 15Last Post: 1st Mar 2016, 21:26 -
Virtualdub plugins
By natty in forum Newbie / General discussionsReplies: 4Last Post: 18th Aug 2015, 13:43 -
Missing compression plugins VirtualDub
By be4con in forum EditingReplies: 4Last Post: 10th Oct 2013, 04:17 -
Regarding arrangement of plugins..
By zanaitoryoushi in forum Video ConversionReplies: 12Last Post: 22nd Aug 2012, 09:21 -
Need plugins
By IT learner in forum EditingReplies: 6Last Post: 12th Sep 2011, 10:49
