I have a WinTV capture card, and I can't seem to get the same channels in the same resolution as my TV. The TV is hooked up with RCA cables from the VCR, which gets its signal through a coax going into the wall. I've tried everything, hooking up WinTV into the wall jack, hooking it up through the VCR, etc... and I can't seem to get a good picture!!! Can anyone help me????
You've either got a faulty tuner module or you need and amplifier for your aerial. You are using an external roof top aerial? Not splitting the aerial and not using a destop portable one? Please provide more details. Try through video inputs. Your TV or VCR has a stronger receiver. Also if you are unlucky your PC could be generating a lot of interference.
<font size=-1>[ This Message was edited by: ironwood321 on 2001-07-29 14:29:56 ]</font>
Joining video files, fine tuning gets annoying
By Anonymous4442 in forum EditingReplies: 4Last Post: 13th May 2011, 11:57 -
Fine tuning for tripod ball-head?
By acusman in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 10th Apr 2011, 20:28 -
fine-tuning a fix for this audio buzz-ringing
By spiritgumm in forum AudioReplies: 12Last Post: 3rd Nov 2010, 22:08 -
Problem fine tuning audio sync
By spark001uk in forum Newbie / General discussionsReplies: 1Last Post: 15th Aug 2009, 15:02 -
Fine-tuning display size on remote plasma
By Fred429 in forum Media Center PC / MediaCentersReplies: 0Last Post: 29th Mar 2008, 03:46
