Let's say I have two TV recordings from the same show but one is in english and one is german.
The english video file is a better quality so I would like to sync the audio from the german video file to the video from the english version.
But two problems.
Problem 1: It doesn't help to change the audio delay with MKVtoolnix or any other tool, because then it's out of sync after 30 seconds again and the pitch is still wrong.
Problem 2: Changing the speed helps the pitch problem, but the audio is still out of sync after a few seconds.
Am I missing something?
Is there a better software solution that automatically syncs it? (Doubt it, but still asking)
Anybody got any ideas?
	If there are no drastic differences in the "cut" of the video(identical scenes and everything), I use an old free version of Reaper to change the playback rate of the new audio until it matches the original.
 Load both into the program so you can see the waveform.....it takes a lot of time but it is done correctly.
 I've heard you can do the same in Audacity but I learned to do it in Reaper. The very first versions of Reaper were free.
 You need to right-click on the new file's waveform in Reaper to bring up properties....and the playback rate change option is in there. Obviously a short video is easier to work with than a long TV episode or movie. I work with music videos that are usually under 5 minutes.
  Proper Tools and Method to Sync Audio from Different Video SourceBy danswano in forum EditingReplies: 16Last Post: 12th May 2014, 17:54
  Suggestion on how to capture video from one source and audio from anotherBy needhelpplease in forum Newbie / General discussionsReplies: 1Last Post: 21st Aug 2013, 11:37
  Using audio from 25fps source on 29.97fps videoBy headless chicken in forum AudioReplies: 5Last Post: 26th Nov 2012, 07:14
  video source with 2 audio channelsBy mo_jai in forum AudioReplies: 1Last Post: 27th Oct 2012, 07:44
  Sync - Resample audio from video source of 29 FPS to 25 FPSBy Chastepe in forum AudioReplies: 6Last Post: 17th Oct 2012, 11:35
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
