  1. hi, i am trying to remove harcoded arabic sub and signature from movizland.com
    they look like signature Pop-up is there a way to remove them losslessly Please help
    No. It's not possible to remove them lossless. You can only blur or add black borders or crop and you must reconvert.
  3. Member Bernix's Avatar
    Apr 2016
    Europe
    I didnt test it but you can try MSU subtitle remover for virtual dub. Its all free. Maybe field custom will erase the arabic text. But for sure if it works it will remove white titles in picture 3. And yes, it is not lossless. https://www.youtube.com/watch?v=hvdkkGJnyMo And yes reconvert is needed.
  4. Originally Posted by Bernix View Post
    followed the video but the sub's are still there tried the filter it doesnt work..i have uploaded the video to try pls help https://userscloud.com/q39lznz8evg6
  5. Member Bernix's Avatar
    Apr 2016
    Europe
    I have very slow computer. So I have to downscaled it. But it worked on some white arabic subtitles and on others not. Set custom, then first pass to create mask. Then choose second option read from mask. In video is this skiped.
    But I think it will not helps you at all. The result is not good. It destructs the picture (alot) somewhere too.
    Sorry
    Bernix
