    Sep 2007
    Unflushable, Turdistan
    It seems almost every DVD I play (I use VLC) gives codec stats for audio as 192k.
    Not sure what is typical (most-used audio bitrate for plain ol' DVD).
    Thx for any insight you may provide!
  2. 192 is typical for stereo. DD5.1 is usually 448.
  3. Yes, typically AC-3 (Dolby Digital) is 192kbps for 2.0 and either 384kbps or 448kbps for 5.1. Some DVDs also have DTS 5.1 which I've found is either 1,509kbps or 755kbps.
