Windows 7
Computer Asus U47A
I keep getting kicked off internet (all other devices are online). I tried resetting modem/router. It will kick me off and go to blue screen where it start dumping information and then restarts. I read online to go to Device Manager to uninstall the wireless card, reboot and have it reinstall. It will work for awhile then do the same thing. Is my hardware dying or some other issue? Windows updates up to date and all drivers up to date.
Results 1 to 21 of 21
I just read a news article about a MS update that causes problems (blue screens) with win 7 and asus mother boards. Asus has a fix so see if that helps.
http://www.cnet.com/news/microsoft-software-update-breaks-windows-7-for-some-users/Extraordinary claims require extraordinary evidence -Carl Sagan -
It is not going to blue screen as much. Now it shows internet as yellow "limited access" which still wont let me connect. I have to restart the computer every single time.
I uninstalled and rebooted and then reinstalled the device. I check the device manager and all updates are current and network adapter Intel Centrino N-2230 is enabled and working properly. What could be the issue?Last edited by jyeh74; 9th May 2016 at 22:03.
Uninstall the old driver first, then update the driver from this link
for win 7 32bit
https://downloadmirror.intel.com/25223/eng/Wireless_18.12.1_%20Ds32.exe
for win 7 64bit
https://downloadmirror.intel.com/25223/eng/Wireless_18.12.1_%20Ds64.exe
good luck!Last edited by anana; 9th May 2016 at 23:21.
Driver 18.2.1 says it is only for version 7265 and 7260 and 3165 and 3160. I have Centrino N-2230 in Windows 7 64 bit. Look like driver 15.17.0.1 is the newest. That's the one I currently have.
Am I misinterpreting something? -
Its not 18.2.1, it's 18.12.1
https://downloadcenter.intel.com/download/25223/Intel-PROSet-Wireless-Software-and-Dri...for-Windows-7-
Here's the proof list
Thanks for catching that Anana. Why does it say driver 17.1.1504.0516 is the latest driver, not 18.12.1
Search by Download Type = "driver" and OS = "Windows 7 64-bit"
https://downloadcenter.intel.com/product/66889/Intel-Centrino-Wireless-N-2230-Single-Band
Are you searching by a different way? -
Like i said before, i don't know about that, maybe 17.1.1504.0516 support more old adapter type & 18.12.1 or later maybe stop support the old adapter type...
For some reason the 18.12.1 won't let me install. When I click on it, it brings up the hourglass screen like it is trying to do something, but goes away. I tried rebooting but still cannot install it.
Make sure to install the right driver for your windows. If win 7 32bit, install the 32bit version. If win 7 64bit, install the 64bit version.
Sometimes the install process need more time, depend on your cpu & hdd/ssd. Just wait until the install process complete.Last edited by anana; 10th May 2016 at 00:54.
I can only install this one, which is strange because I do a reboot and after my computer restarts, when I go to my Device Manager, Network Adapters and go to Properties and select the Driver tab, it shows the driver as version 15.17.0.1 with driver date 4/30/15. That doesn't match the driver 17.1.1504.0516 with date 8/28/15
Is it not reflecting the correct driver or is it just not installing?
https://downloadcenter.intel.com/download/25208/Intel-PROSet-Wireless-Software-for-Blu...?product=66889
It will download this one, but won't install when I click on it.
https://downloadcenter.intel.com/download/25223/Intel-PROSet-Wireless-Software-and-Dri...?product=66889
When I got to "uninstall program" to remove the previous adapter driver, there is no UNINSTALL button, only CHANGE or REPAIR. Is that normal?Last edited by jyeh74; 10th May 2016 at 01:08.
And why it is when I hit "update driver" from the Device Manager, it is not locating the 18.12.1 driver for me? It's showing my old 15.17.0.1 (which completely does not match the 17.1.1504.0516 version I installed) as the newest version.
I'm on the Intel website. So do you mean because the file says it is version 17.1.1504.0516, it doesn't mean that the driver is 17.1.1504.0516. It's just a naming convention?
I can't get version 18.12.1 or 18.12.0 exe files, which are newer based on a higher number than the version 17.1.1504.0516, but older dates, to install. -
just learn from this
If the main problem fixed, then close this thread.Last edited by anana; 10th May 2016 at 01:45.
anana, it was working fine after the driver update. Recently the internet connection started going to "limited access" which resulted in me not being able to get online. If I go to device manager and disable and enable it, then it will work. It seems intermittent. Other devices connect fine. Does this sound normal?
It depends on your ISP or router settings or firewall application...
I don't know for sure.
Wireless printer issue
By jyeh74 in forum Newbie / General discussionsReplies: 29Last Post: 6th Sep 2014, 09:30 -
Wireless PC Screen to TV Screen Clone
By king818 in forum Media Center PC / MediaCentersReplies: 0Last Post: 16th Sep 2013, 02:47 -
Convertxtodvd causing Computer Blue screen
By jbitakis in forum Authoring (DVD)Replies: 14Last Post: 29th Nov 2012, 12:46 -
HELP! Black screen/Blue Screen problem
By will7370 in forum ComputerReplies: 2Last Post: 1st Apr 2012, 09:30 -
Playing the tape on the camcorder only shows a blue screen.
By seven1970 in forum Capturing and VCRReplies: 9Last Post: 23rd Mar 2012, 17:44
