In Windows 10, consider the following line in VapourSynth:
The stream is VC-1, though. Suddenly getting dozens of these (see below). Make me wonder, does LWLibavSource even support VC-1?! Looks like the underlying FFMpeg code is real flaky.Code:vid = core.lsmas.LWLibavSource ("f:/jobs/wm.mkv")
I was hoping to avoid having to install ffdshow tools under Win 10, but I may have to. Not even sure LWLibavSource's libav dependency can be overriden, though.
Any suggestions would be welcome.
Code:x264 [info]: OpenCL acceleration enabled with NVIDIA Corporation GeForce GTX 980 x264 [info]: Compiling OpenCL kernels... x264 [info]: profile High, level 4.1 [vc1 @ 00000236bd0cbe80] warning: first frame is no keyframe [vc1 @ 00000236bd0cbe80] warning: first frame is no keyframe [vc1 @ 00000236bd0cbe80] warning: first frame is no keyframe [vc1 @ 00000236bd0cbe80] warning: first frame is no keyframe [vc1 @ 00000236bd0cbe80] warning: first frame is no keyframe [vc1 @ 00000236bd0cbe80] warning: first frame is no keyframe [vc1 @ 00000236bd0cbe80] warning: first frame is no keyframe [vc1 @ 00000236bd0cbe80] warning: first frame is no keyframe [vc1 @ 00000236bd0cbe80] warning: first frame is no keyframe [vc1 @ 00000236bd0cbe80] warning: first frame is no keyframe [vc1 @ 00000236bd0cbe80] warning: first frame is no keyframe [vc1 @ 00000236bd0cbe80] warning: first frame is no keyframe [vc1 @ 00000236bd0cbe80] warning: first frame is no keyframe [vc1 @ 00000236bd0cbe80] warning: first frame is no keyframe [vc1 @ 00000236bd0cbe80] warning: first frame is no keyframe [vc1 @ 00000236bd0cbe80] warning: first frame is no keyframe [vc1 @ 00000236bd0cbe80] warning: first frame is no keyframe [vc1 @ 00000236bd0cbe80] warning: first frame is no keyframe [vc1 @ 00000236bd0cbe80] warning: first frame is no keyframe [vc1 @ 00000236bd0cbe80] warning: first frame is no keyframe [vc1 @ 00000236bd0cbe80] warning: first frame is no keyframe [vc1 @ 00000236bd0cbe80] warning: first frame is no keyframe [vc1 @ 00000236bd0cbe80] warning: first frame is no keyframe [vc1 @ 00000236bd0cbe80] warning: first frame is no keyframe [vc1 @ 00000236bd0cbe80] warning: first frame is no keyframe [vc1 @ 00000236bd0cbe80] warning: first frame is no keyframe [vc1 @ 00000236bd0cbe80] warning: first frame is no keyframe [vc1 @ 00000236bd0cbe80] warning: first frame is no keyframe [vc1 @ 00000236bd0cbe80] warning: first frame is no keyframe [vc1 @ 00000236bd0cbe80] warning: first frame is no keyframe [vc1 @ 00000236bd0cbe80] warning: first frame is no keyframe [vc1 @ 00000236bd0cbe80] warning: first frame is no keyframe [vc1 @ 00000236bd0cbe80] warning: first frame is no keyframe [vc1 @ 00000236bd0cbe80] warning: first frame is no keyframe [vc1 @ 00000236bd0cbe80] warning: first frame is no keyframe [vc1 @ 00000236bd0cbe80] warning: first frame is no keyframe [vc1 @ 00000236bd0cbe80] warning: first frame is no keyframe [vc1 @ 00000236bd0cbe80] warning: first frame is no keyframe [vc1 @ 00000236bd0cbe80] warning: first frame is no keyframe [vc1 @ 00000236bd0cbe80] warning: first frame is no keyframe [vc1 @ 00000236bd0cbe80] warning: first frame is no keyframe [vc1 @ 00000236bd0cbe80] warning: first frame is no keyframe [vc1 @ 00000236bd0cbe80] warning: first frame is no keyframe [vc1 @ 00000236bd0cbe80] warning: first frame is no keyframe [vc1 @ 00000236bd0cbe80] warning: first frame is no keyframe [vc1 @ 00000236bd0cbe80] warning: first frame is no keyframe [vc1 @ 00000236bd0cbe80] warning: first frame is no keyframe [vc1 @ 00000236bd0cbe80] warning: first frame is no keyframe [vc1 @ 00000236bd0cbe80] warning: first frame is no keyframe [vc1 @ 00000236bd0cbe80] warning: first frame is no keyframe [vc1 @ 00000236bd0cbe80] warning: first frame is no keyframe [vc1 @ 00000236bd0cbe80] warning: first frame is no keyframe [vc1 @ 00000236bd0cbe80] warning: first frame is no keyframe [vc1 @ 00000236bd0cbe80] warning: first frame is no keyframe [vc1 @ 00000236bd0cbe80] warning: first frame is no keyframe [vc1 @ 00000236bd0cbe80] warning: first frame is no keyframe [vc1 @ 00000236bd0cbe80] warning: first frame is no keyframe [vc1 @ 00000236bd0cbe80] warning: first frame is no keyframe [vc1 @ 00000236bd0cbe80] warning: first frame is no keyframe [vc1 @ 00000236bd0cbe80] warning: first frame is no keyframe [vc1 @ 00000236bd0cbe80] warning: first frame is no keyframe [vc1 @ 00000236bd0cbe80] warning: first frame is no keyframe [vc1 @ 00000236bd0cbe80] warning: first frame is no keyframe
Results 1 to 14 of 14
Warnings are no reasons to panic.
If libavcodec did not support VC-1 decoding, you would not get your video decoded at all, because LwLibavVideoSource would not use any other decoder than the ones it has compiled in. If it would not contain a VC-1 decoder, it would definitely not try to use a system installed DirectShow or Media Foundation codec, but fail instead.
Does the video decode at all? Does the result look fine? ... Then ignore the warnings. They are possibly just on a nerdy level (like, can VC-1 have "open GOPs" and have a GOP start with a B frame?). -
Thanks. But yeah, the output is utter garbage (just white flickering).
I was just going to set up VapourSynth, in a Vmware box, to experiment with ffdshow. But if libav is statically built-in, then I guess that's a no-no too. -
It's not interlaced. See for yourself:
Code:General ID : 1 (0x1) Complete name : F:\jobs\wm-sample.m2ts Format : BDAV Format/Info : Blu-ray Video File size : 309 MiB Duration : 1mn 59s Overall bit rate mode : Variable Overall bit rate : 21.6 Mbps Maximum Overall bit rate : 35.5 Mbps Video ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : VC-1 Format profile : Advanced@L3 Codec ID : 234 Duration : 2mn 0s Bit rate : 20.8 Mbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 23.976 (24000/1001) fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Compression mode : Lossy Bits/(Pixel*Frame) : 0.417 Stream size : 297 MiB (96%)
And here is a sample on my OneDrive:
wm-sample
The sample I muxed to .m2ts, btw, and it then gives me a far clearer hint:
Code:[mpegts @ 00000222de386cc0] Failed to open codec in av_find_stream_info
This is only the simple analysis output, not the extended analysis output.
If you have the CLI version, use: MediaInfo -f F:\jobs\wm-sample.m2ts
If you have the GUI version, enable the "Extended mode" in the "Debug" menu. -
Why, here it is:
Code:General Count : 322 Count of stream of this kind : 1 Kind of stream : General Kind of stream : General Stream identifier : 0 ID : 1 ID : 1 (0x1) Count of video streams : 1 Video_Format_List : VC-1 Video_Format_WithHint_List : VC-1 Codecs Video : VC-1 Complete name : F:\jobs\wm-sample.m2ts Folder name : F:\jobs File name : wm-sample File extension : m2ts Format : BDAV Format : BDAV Format/Info : Blu-ray Video Format/Extensions usually used : m2ts Commercial name : BDAV Codec : BDAV Codec : BDAV Codec/Info : Blu-ray Video Codec/Extensions usually used : m2ts File size : 324390912 File size : 309 MiB File size : 309 MiB File size : 309 MiB File size : 309 MiB File size : 309.4 MiB Duration : 119953.164063 Duration : 1mn 59s Duration : 1mn 59s 953ms Duration : 1mn 59s Duration : 00:01:59.953 Duration : 00:02:00;02 Duration : 00:01:59.953 (00:02:00;02) Overall bit rate mode : VBR Overall bit rate mode : Variable Overall bit rate : 21619536 Overall bit rate : 21.6 Mbps Maximum Overall bit rate : 35500000 Maximum Overall bit rate : 35.5 Mbps Frame rate : 23.976 Frame rate : 23.976 fps Frame count : 2878 Stream size : 12948147 Stream size : 12.3 MiB (4%) Stream size : 12 MiB Stream size : 12 MiB Stream size : 12.3 MiB Stream size : 12.35 MiB Stream size : 12.3 MiB (4%) Proportion of this stream : 0.03992 File creation date : UTC 2016-05-04 08:56:51.330 File creation date (local) : 2016-05-04 10:56:51.330 File last modification date : UTC 2016-05-04 08:20:19.763 File last modification date (local) : 2016-05-04 10:20:19.763 Video Count : 333 Count of stream of this kind : 1 Kind of stream : Video Kind of stream : Video Stream identifier : 0 StreamOrder : 0-0 ID : 4113 ID : 4113 (0x1011) Menu ID : 1 Menu ID : 1 (0x1) Format : VC-1 Commercial name : VC-1 Format profile : Advanced@L3 Internet media type : video/vc1 Codec ID : 234 Codec : VC-1 Codec : VC-1 Codec/Family : VC-1 Codec/Url : http://www.microsoft.com/windows/windowsmedia/format/codecdownload.aspx Codec profile : Advanced@L3 Duration : 120037 Duration : 2mn 0s Duration : 2mn 0s 37ms Duration : 2mn 0s Duration : 00:02:00.037 Duration : 00:02:00;02 Duration : 00:02:00.037 (00:02:00;02) Bit rate : 20756502 Bit rate : 20.8 Mbps Width : 1920 Width : 1 920 pixels Height : 1080 Height : 1 080 pixels Sampled_Width : 1920 Sampled_Height : 1080 Pixel aspect ratio : 1.000 Display aspect ratio : 1.778 Display aspect ratio : 16:9 Frame rate : 23.976 Frame rate : 23.976 (24000/1001) fps FrameRate_Num : 24000 FrameRate_Den : 1001 Frame count : 2878 Resolution : 8 Resolution : 8 bits Colorimetry : 4:2:0 Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 Bit depth : 8 bits Scan type : Progressive Scan type : Progressive Interlacement : PPF Interlacement : Progressive Compression mode : Lossy Compression mode : Lossy Bits/(Pixel*Frame) : 0.417 Delay : 4200000.000 Delay : 1h 10mn Delay : 1h 10mn 0s 0ms Delay : 1h 10mn Delay : 01:10:00.000 Delay, origin : Container Delay, origin : Container Stream size : 311442765 Stream size : 297 MiB (96%) Stream size : 297 MiB Stream size : 297 MiB Stream size : 297 MiB Stream size : 297.0 MiB Stream size : 297 MiB (96%) Proportion of this stream : 0.96008 Buffer size : 3749952 format_identifier : VC-1
I downloaded your sample. Currently using AviSynth+ (r1847, MT-pfmod), L-SMASH Source for AviSynth 32b r785: Works well, video looks good.
So if there is any issue, it must be in the VapourSynth version. Just tried to load with a version that came with an older StaxRip, and it fails opening the video source. I'll have to update and try again with current versions... -
Thanks for all your testing so far!
Turns out Windows Media Player can't play VC1 either; what a joke! I'm on Windows 10 pro, 64-bit, btw. You'd think they'd finally added VC1 support by now! The KMPlayer shows it just fine, as well as PowerDVD 15. So, I'll investigate in that area some more. -
MPC-HC 1.7.10 (using LAV Filters, video playback decoders using the same libavcodec kernel as L-SMASH Source) can play the sample just fine.
BTW, congratulations to your taste, "Watchmen" is one of only few movies I would even consider buying...
_
Now, updated VapourSynth x64 to R32, and StaxRip x64 to v1.3.4.0 stable; still, VirtualDub x64 v1.10.4 can't open the script.
Code:--------------------------- VirtualDub Error --------------------------- Avisynth open failure: Python exception: [Fatal]: Failed to read an input file Traceback (most recent call last): File "src\cython\vapoursynth.pyx", line 1491, in vapoursynth.vpy_evaluateScript (src\cython\vapoursynth.c:26897) File "H:\Video\Test\wm-sample.vpy", line 5, in <module> clip = core.lsmas.LibavSMASHSource(source = r'H:\Video\Test\wm-sample.m2ts'); File "src\cython\vapoursynth.pyx", line 1383, in vapoursynth.Function.__call__ (src\cython\vapoursynth.c:25204) vapoursynth.Error: [Fatal]: Failed to read an input file
Code:import vapoursynth as vs; core = vs.get_core(); core.std.LoadPlugin(r'E:\Programme\StaxRip\Apps\Plugins\vs\vslsmashsource\vslsmashsource.dll'); clip = core.lsmas.LibavSMASHSource(source = r'H:\Video\Test\wm-sample.m2ts'); clip.set_output();
P.S.: My bad; that worked with an MP4, but for M2TS I need LWLibavSource.
Code:import vapoursynth as vs; core = vs.get_core(); core.std.LoadPlugin(r'E:\Programme\StaxRip\Apps\Plugins\vs\vslsmashsource\vslsmashsource.dll'); clip = core.lsmas.LWLibavSource(source = r'H:\Video\Test\wm-sample.m2ts'); clip.set_output();
x264_64 from MeGUI runs nicely, no vc1 warnings. Only one
Code:[mpegts @ 0000000000599120] Failed to open codec in av_find_stream_info
Thanks for the compliment, for starters.
Strange how different versions of VapourSynth matter. I think I forgot to mention it (here), but I'm using the static version of LWLibavSource (as the dynamic one crashes on sight for me, for some reason).
I still get the impression that somewhere along the line a VC1 codec is missing somewhere. As my version of LWLibavSource is static, there is, like you said, no real way for me to manipulate it externally (like with ffdshow).
More at 11 (no really, as I need to catch me a few hours sleep now first: been up way too long).
And, once again, thanks for all your extensive testing! -
Oh my, I completely misunderstood you! I thought the Failed to open codec in av_find_stream_info meant it still didn't work, but it *does*!!
So, what can we conclude here? That the original mkv file I used (demuxed with eac3to) makes LWLibavSource crap out, badly (but only for VC1, it would appear, as all H264 stuff I normally demux to .mkv works just fine). And that the later .m2ts version (remuxed with tsMuxeR) works fine too! (Sans that one error, which seems rather fatal, but actually turns out to be completely harmless, LOL).
Again, my deep appreciation for the time and effort you put into this, helping to resolve this!
(Willing to pay)ffmpeg Need help downloading live stream ffmpeg and rtmp
By grabyea in forum Video Streaming DownloadingReplies: 0Last Post: 10th Apr 2016, 17:54 -
FFMPEG QUESTION :How do I take 10bit jpeg with FFMPEG?
By Jamaika in forum Video ConversionReplies: 10Last Post: 6th Jul 2015, 14:41 -
FFmpeg Runtime error / FFmpeg git-df82454 32-bit Static (2012-10-03)
By MashedPotatoes in forum Newbie / General discussionsReplies: 5Last Post: 6th Oct 2012, 18:22 -
FFmpeg on Win only - FAQ can ffmpeg realize screen capture
By feelart in forum Capturing and VCRReplies: 1Last Post: 14th Feb 2012, 05:11 -
Which ffmpeg options are used behind the scenes by ffmpeg?
By roberto.aloi in forum ffmpegX general discussionReplies: 1Last Post: 26th Jul 2011, 06:09
