I want to use two web cams to record my school's spring concert. One will be fixed - wide angle, and the other will be a bit mobile and will zoom in on a duet, solo, etc. If I use "real" cameras, with hdmi cables, i will need to spend at least $1K to get a switch to smoothly manage this process. I think Open Broadcaster is capable of managing two USB cameras. has anyone ever used this setup? The ultimate goal is to upload realtime to a website, where all of the grannies and aunties from across the country can see their adorable grandchild/niece/nephew perform. I have noticed that some USB webcams advertise HD. Does anyone know if any have white balance capabilities, or other ways of tuning the picture?
Sound will be recorded by a system of microphones with a mixer, then connected to the computer, where it will be uploaded to the www.
Check out ManyCam Studio. You set it as your camera in whatever streaming software you're using, then select and switch between multiple UBS cameras, images (think a background you're broadcasting while you wait for the event to start), microphones,other audio inputs. No white balance (at least in my current version, 5.05), but it does have brightness, contract, saturation, and separate red/green/blue adjustments to the color. To tell the truth, I haven't used it much, only for one live stream, but it works very well.
Two different cameras
By Anon45 in forum Portable VideoReplies: 6Last Post: 1st Jun 2018, 07:31 -
OT: Hacking Cameras
By ahhaa in forum ComputerReplies: 12Last Post: 10th May 2015, 03:37 -
Wha is the proper name of that video cameras? Are they amateur cameras?
By Stears555 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 9th Jul 2014, 17:06 -
Cannon HD cameras
By Tom in HD in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 11th Jan 2012, 15:59 -
DSLR Cameras
By Nsalley in forum AudioReplies: 4Last Post: 3rd Sep 2011, 08:32
