I have a Sony HDR-CX130 and I capture in AVCHD format. .mts
I have a licensed copy of NeatVideo Dub and installed VirtualDub AIO and it will load MTS files fine.
This camera tends to create images with noise. not much but enough to warrant using NV which creates outstanding results.
I will most likely never burn these to BluRay and would like to keep the files in the best possible format.
What compression should I save the edited videos to? MP4? Keep 1920x1080 I assume? No need to reduce size and quality.
I have plenty of disk space and external drives for storage.
Any suggestions would be welcome!!
Lannie
I also noticed some were recorded in interlaced and some progressive. I must have been messing with the settings while learning to use it.
I assume the final format should be progressive? How do I determine the exact mode it was recorded in? -
That's what I ended up doing. I found the TEXt output of Mediainfo showed me my file types. Apparantly I was messing around with the camera a lot on our Carnival Cruise. 4 different record modes. lol
I found out how to configure the External encoding with VD and I am using the x264 like you suggested. With NV 4.1 and yadif deinterlace I am able to get all my videos to 1920x1080p format. The results are terrific! Getting about 8fps on my modest system which I didn't think was too bad for the file types and NV filtering.
It does take advantage of the CPU and GPU cores which helps a lot.
Intel i5-4570 Quad core
8Gb DDR3
AMD HD 7770 Video with 1Gb ram and 4 cores.
2 x 1Tb WD drives with 32Mb buffer.
NV helps make my videos look like they came from a much better HD camera.
Lannie -
I found the exporting with an external encoder on the following forum:
http://forum.timescapes.org/phpBB3/viewtopic.php?f=4&t=716
About 2/3rd the way down the page. They don't clearly state it but I created a folder under VirtualDub called Encoders and put the three folders/apps under each respective folder.
So far this is working very well.
Lannie
PS: I am using version 1.10.4 of VD and the latest NV 4.1.
VirtualDub Batch Conversation with MTS files?
By khan.cross in forum Video ConversionReplies: 2Last Post: 24th May 2015, 03:09 -
How to merge multiple .mts files (canon HF) into one single .mts file
By frmsuv2van in forum Video ConversionReplies: 15Last Post: 5th Sep 2014, 22:21 -
Load AVCHD Lite mts files into VirtualDub?
By MJ Peg in forum Video ConversionReplies: 18Last Post: 1st Aug 2012, 13:28 -
Removing Noise.. NeatVideo VirtualDub problem
By David Animator in forum EditingReplies: 2Last Post: 1st Apr 2012, 17:43 -
Cannot get MTS files into virtualdub.
By jtl999 in forum Newbie / General discussionsReplies: 0Last Post: 28th Feb 2012, 22:41
